Re: Rate my Dana 60 gear contact pattern
[Re: 65Fury440]
#2565619
10/17/18 10:03 PM
10/17/18 10:03 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
I know nothing about setting up the contact but just ran across this video and it may or may not be helpful. https://youtu.be/BBA8KjUGsXw
[Re: 65Fury440]
#2565654
10/17/18 10:32 PM
10/17/18 10:32 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Yes - get the backlash in spec. You're close.
[Re: moper]
#2565722
10/18/18 12:22 AM
10/18/18 12:22 AM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
Yes - get the backlash in spec. You're close. What do you think my next move should be? I was going to shim the carrier to the right into the pinion gear? Not sure what it would do the the depth of the pattern into the ring gear?
[Re: 4406bbl]
#2565780
10/18/18 04:40 AM
10/18/18 04:40 AM
65Fury440
Spring Hill Fl
Yes move toward pinion about .012-.015. Do you have some slip bearings to make your life easy? If not you can make some with a dremel and a few sanding drums, sand them out till they slip on carrier rather than pulling bearings 10 times. I found out that a dremel works after I bought a set. No but I broke down and bought a press. At this point, buying a couple sacrificial bearings would be merciful.
