1970 b5 blue paint code #2565606
10/17/18 09:40 PM
10/17/18 09:40 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
im doing some under hood touch up,
does anyone have the mixture code for 1970 b5 blue?
i had a pint mixed of omega paint and i think its a different year b5 its much brighter blue
Re: 1970 b5 blue paint code [Re: mcat4321] #2565671
10/17/18 10:50 PM
10/17/18 10:50 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Chrysler codes:
1969-1970 = EB5
1971-1973 = GB5
You can Google "Chrysler EB5 paint reference" and should be able to find a link to a cross-reference from the factory code to various paint suppliers' mixing codes.
Re: 1970 b5 blue paint code [Re: mcat4321] #2565678
10/17/18 10:56 PM
10/17/18 10:56 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 paint chip charts with the original vendor codes at http://www.hamtramck-historical.com/paintChipCharts/1970PaintChipCharts-01.shtml
Re: 1970 b5 blue paint code [Re: mcat4321] #2565686
10/17/18 11:15 PM
10/17/18 11:15 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
thank you guys
Re: 1970 b5 blue paint code [Re: mcat4321] #2565697
10/17/18 11:29 PM
10/17/18 11:29 PM
BlueRacer69 Offline
BlueRacer69  Offline
Whoever mixed the paint for you may have mixed 68 or 69 B5 blue instead of 70 B5 blue. I think as time went on, each year got a little bit darker blue. I remember being at a car show once and seeing 2 B5 blue cars parked side by side. One was a 69 and the other a 70 model, and you could clearly see that 70 car was a little darker blue and not as bright blue as the 69 car.
Re: 1970 b5 blue paint code [Re: mcat4321] #2565701
10/17/18 11:43 PM
10/17/18 11:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1969 B5 is the same as 1970 EB5.
1971 GB5 was a different mix.
Things like how accurate the factory mix was, temperature & humidity when it was sprayed, etc., etc. can all affect what our eyes see after the paint cures.
Add in the older repaints & the newer base / clear paints & not all original colors are shown as they originally were.
Re: 1970 b5 blue paint code [Re: mcat4321] #2565744
10/18/18 01:24 AM
10/18/18 01:24 AM
3
340clone Offline
340clone  Offline
I always thought the '71 B5 had a greenish hue to it, when compared to the earlier years.
Re: 1970 b5 blue paint code [Re: 340clone] #2565935
10/18/18 02:12 PM
10/18/18 02:12 PM
BradH Offline
BradH  Offline
Re the pic attached...
- I THINK the rear license plate bracket that came off my car shows a GB5 repaint, even though my car came w/ a spare quart of EB5 that wasn't a good match for the car
- The test strip shown below the bracket is the "modern" B5 like a new Challenger color option, which is supposedly based on EB5
- The old paint factory chips IMO show EB5 being more of a "pure" blue, whereas I agree the GB5 has that greenish tint in comparison
As someone else pointed out, there are sooooo many variables that come into play when trying to identify paint colors. Just a change in the lighting when I was taking pics like the above made the differences in the colors appear far more extreme than they looked to me. This one looked more "real" than some of the others I took.
shruggy
Re: 1970 b5 blue paint code [Re: BradH] #2565938
10/18/18 02:19 PM
10/18/18 02:19 PM
BradH Offline
BradH  Offline
This 1970 color chart shows what I think is "typical" for EB5.
Re: 1970 b5 blue paint code [Re: BradH] #2565942
10/18/18 02:31 PM
10/18/18 02:31 PM
BradH Offline
BradH  Offline
Here's another one from the test strip... lots of metal flake, like the EB5 color chip in the chart above... Testors 1-coat lacquer hobby paint.
Re: 1970 b5 blue paint code [Re: mcat4321] #2565957
10/18/18 02:55 PM
10/18/18 02:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had my local paint supply store mix up some for me so I could paint my engine bay & roll cage and other parts. Original paint on the car was PPG & they matched it perfectly.
rsz_rsz_20160507_120139.jpgrsz_100_1667_[640x480].jpgChallenger Progress 018 [640x480].jpg
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 1970 b5 blue paint code [Re: mcat4321] #2566401
10/19/18 12:02 PM
10/19/18 12:02 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I went trough this with my dads 68 charger .
I will tell you the 68 color is more of a turquoise blue .
when mixed in single stage Centari enamel was the closest to original .
the 73 B5 has more of a purple / dark tinge.
68-69 I think were the same .
70 not sure could be a different mix,
1969 Dodge Charger 1969 Dodge Superbee
Re: 1970 b5 blue paint code [Re: cjs69mope] #2566516
10/19/18 03:30 PM
10/19/18 03:30 PM
BradH Offline
BradH  Offline
68 is different than 69-70
71-73 is another color
74 changed again
