Remote side mirror installation on 71 B-Body #2560976
10/08/18 05:00 PM
10/08/18 05:00 PM
Los Angeles, CA
JF_Moparts Offline OP
Los Angeles, CA
I'm trying to determine if, when installing a remote side mirror on a 71 B body, you are supposed to route & secure the three cables that go from the mirror to the remote control on the door panel.
I've looked in both the original chassis and body service manuals but they don't mention it.
I'm asking because I just had a side mirror installed by a restoration place and they secured the cables with zip ties. As a result the cables are stretched and they are getting stuck on the window mounts when the window is raised and lowered.
Anyone have any knowledge on this?
Thank you!
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2560979
10/08/18 05:12 PM
10/08/18 05:12 PM
Los Angeles, CA
Los Angeles, CA
Here's a picture (best I could get) of how the cables are mounted within the door.
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2562344
10/11/18 10:48 AM
10/11/18 10:48 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
That bottom thing in your photo that's marked as a tie should be secured to the leading edge of the door. There's a hole for it and the barbed end of the plastic piece gets pushed through from the inside out. That keeps the cables from getting caught up when the window goes up and down.
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2564276
10/15/18 08:43 AM
10/15/18 08:43 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Mine got jus 2 ties. One snaps on in front of door close to the door hinge, the other one on inner side/face ( covered by the door panel ) this has being talked and posted at the 3rd gen charger board
Re: Remote side mirror installation on 71 B-Body [Re: NachoRT74] #2564713
10/16/18 02:34 AM
10/16/18 02:34 AM
Los Angeles, CA
Los Angeles, CA
Thanks for the replies. Where's that 3rd gen Charger board?
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2564985
10/16/18 06:06 PM
10/16/18 06:06 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Sorry! I thought had posted the link LOL
http://wichargerguy.proboards.com/
Re: Remote side mirror installation on 71 B-Body [Re: NachoRT74] #2565098
10/16/18 10:01 PM
10/16/18 10:01 PM
None
71rm23 Offline
71rm23  Offline
None
Didn't find the topic Nacho.
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2565229
10/17/18 07:37 AM
10/17/18 07:37 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I know have better pics from another thread, but this is the one I found on a quick search
http://wichargerguy.proboards.com/thread/17651/remote-drivers-mirror
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2565232
10/17/18 07:51 AM
10/17/18 07:51 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
your lucky day! found the pic I grabbed back in the day from the thread mentioned ( not the one I posted )
Check for the words MIRROR wrotten with a sharpie... front of door and close to the joystick location. The thread I posted is not right on one of the locations posted.
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2565233
10/17/18 07:52 AM
10/17/18 07:52 AM
None
71rm23 Offline
71rm23  Offline
None
Don't they clip into a square hole?
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2565236
10/17/18 08:00 AM
10/17/18 08:00 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
no, round holes.
check where the arrows are pointing out
Re: Remote side mirror installation on 71 B-Body [Re: NachoRT74] #2565520
10/17/18 07:01 PM
10/17/18 07:01 PM
Los Angeles, CA
Los Angeles, CA
Great, thank you.
Now I just have to figure out how to contort my body to actually reach those clips. Gymnastic lessons? Yoga?
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2565879
10/18/18 12:53 PM
10/18/18 12:53 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Somebody told on board you could try lace the clip with small cord or nylon and get it trought the front hole to pull it out with it. I could reach it with my arm thought. Not easy!
Re: Remote side mirror installation on 71 B-Body [Re: NachoRT74] #2566312
10/19/18 03:08 AM
10/19/18 03:08 AM
None
71rm23 Offline
71rm23  Offline
None
Thanks for the picture Nacho and yes, round hole in the previous question.
As far as the first hole, I too, couldn't get that sucker in and isn't easy. After spending over an hour trying to get my arm in there, to find that hole, try to push it through, I put one of these on for the first hole and done.
http://www.clipsandfasteners.com/Push-Mount-Cable-Tie-For-Imports-200mm-Length-p/a20380.htm
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2566409
10/19/18 12:14 PM
10/19/18 12:14 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
My original clips are long gone. I fish a cable tie with the fat end too big to go through the hole in from the outside of the door, wrap it around the cable, and push the end back through the hole.
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2566425
10/19/18 12:30 PM
10/19/18 12:30 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
They are available new, with open end to reinstall them... on several sizes
Any local supplier must have them. Is not a Mopar thing, just used that for the search.
https://www.ebay.com/itm/Mopar-Dodge-Ply...4-/190716013487
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2569507
10/25/18 07:58 PM
10/25/18 07:58 PM
Los Angeles, CA
Los Angeles, CA
NachoRT74, thanks for posting that pic, it helped a lot. I just got the old mirror out and a replacement in.
I'm very disappointed that the shop that installed the mirror didn't use the black clips at all.
1) They used a zip tie near the inner control, which was positioned too far from the control to prevent the cables from interfering with the window travel.
2) They added a metal bracket and attached it to the inner door via a bolt through the front clip hole. Fortunately I was able to remove this bracket with little trouble.
Re: Remote side mirror installation on 71 B-Body [Re: JF_Moparts] #2569674
10/26/18 11:06 AM
10/26/18 11:06 AM
None
71rm23 Offline
71rm23  Offline
None
I'd be hot at the shop that did that
