Decoding A833 Transmission #2564720
10/16/18 03:37 AM
10/16/18 03:37 AM
Germany
rubberduck Offline OP
Germany
Please can anybody decode this transmission?
It is an aluminum caseand it is an overdive.23 spline.
Would it fit for a 68 Charger?
Mario
Re: Decoding A833 Transmission [Re: rubberduck] #2564778
10/16/18 11:29 AM
10/16/18 11:29 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Not an expert but I think the aluminum OD units are from mid-70s A-Body cars. Shifter is in the wrong position for your B-body but may be able to change the tail shaft housing (and shaft?). one of the pics here show where the shifter mounts are for the various cars. http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
Re: Decoding A833 Transmission [Re: rubberduck] #2564832
10/16/18 02:18 PM
10/16/18 02:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They made both types of A833OD.
A/F/J/M and B/E/C/truck lengths
If you have one shift mount pad on the tail shaft it's not the one you want. If it has two shift pad mounts, even if both and not drilled and tapped, that is the B/E/C/truck application
Don't be the exception.
