#2564720 - 10/16/18 01:37 AM Decoding A833 Transmission
rubberduck Offline
Loc: Germany
Please can anybody decode this transmission?
It is an aluminum caseand it is an overdive.23 spline.
Would it fit for a 68 Charger?
Mario
#2564778 - 10/16/18 09:29 AM Re: Decoding A833 Transmission [Re: rubberduck]
gzig5 Offline
Loc: Mequon, WI
Not an expert but I think the aluminum OD units are from mid-70s A-Body cars. Shifter is in the wrong position for your B-body but may be able to change the tail shaft housing (and shaft?). one of the pics here show where the shifter mounts are for the various cars. http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
#2564832 - 10/16/18 12:18 PM Re: Decoding A833 Transmission [Re: rubberduck]
Supercuda Offline
I want my mommy!!
Loc: up yours
They made both types of A833OD.
A/F/J/M and B/E/C/truck lengths
If you have one shift mount pad on the tail shaft it's not the one you want. If it has two shift pad mounts, even if both and not drilled and tapped, that is the B/E/C/truck application
Don't be the exception.
25,700 Registered Members
196,768 Topics
340 6 BBL intake id ?
by moparx
01/20/19 12:02 PM
When you are bored in the Iowa winter. Mopar related!
by tboomer
01/20/19 10:57 AM
Best Way to Strip and Refinish Steel Rim
by floyd
01/20/19 10:49 AM
2002 24valve, I need a little more power
by RV2
01/20/19 10:44 AM
