Re: 1999 Dodge truck wiring harness into a 1972 W200 [Re: lowell66dart] #2569908
10/26/18 07:49 PM
10/26/18 07:49 PM
south louisiana
lowell66dart Offline OP
south louisiana
Hope I don't get in trouble for this but just trying to help folks who help me. NPD looks like they are getting out of the 72-93 sheetmetal business. I just paid $31 apiece for two fenders. They are 20 gauge just like my old ones. Don't know about fit yet. Shipping was $150. They have other parts too.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: 1999 Dodge truck wiring harness into a 1972 W200 [Re: lowell66dart] #2569970
10/26/18 10:33 PM
10/26/18 10:33 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Got a link for "NPD" and who are they?
Re: 1999 Dodge truck wiring harness into a 1972 W200 [Re: lowell66dart] #2570138
10/27/18 10:49 AM
10/27/18 10:49 AM
south louisiana
south louisiana
National Parts Depot in North Carolina.
Re: 1999 Dodge truck wiring harness into a 1972 W200 [Re: lowell66dart] #2570244
10/27/18 03:41 PM
10/27/18 03:41 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Auto sensor is a little longer. You can actually use it by spacing it with washers if it's all you have. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 1999 Dodge truck wiring harness into a 1972 W200 [Re: lowell66dart] #2570973
10/29/18 01:46 PM
10/29/18 01:46 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Lowelldart, if you wouldn't mind sir could you post some pics of the wires and color codes showing which couple wires need to be hooked where to run the OBD1 system from the 95? I can handle the soldering and connections, but trying to follow a wiring diagram over multiple pages of the service manual isn't my forte.
Re: 1999 Dodge truck wiring harness into a 1972 W200 [Re: mgoblue9798] #2571721
10/30/18 06:22 PM
10/30/18 06:22 PM
south louisiana
south louisiana
I have decided to do this the easy way. I just got back from pulling the 95 wiring harness from under the hood and dash. I also removed the steering column. All I have left to remove is the fuel tank and lines and the rear harness to the fuel pump and rear lights. I am not modifying the harness. I am using all of it.
I have been cleaning things up a bit too, washing the axles and frame. Just got in a new 4 inch lift kit.
Front and rear glass removed. Anyone have experience with a quality rear slider window? No AC in this truck and I need airflow.
I found a busted front leafspring bracket and need a replacement bad. I will post an ad in the classifieds here.
