Re: Top cat whiskers.
[Re: 71TA]
#2564311
10/15/18 11:15 AM
10/15/18 11:15 AM
Posts: 305 Georgia
69bfan
Georgia
Would it be possible to list the part number that is on the back of the felts? It may be a situation that they were an over the counter part from the late 70s and that is what was provided to them at the dealership.
All of the post / sedan 68 to 70 B-Body window felts that were documented for the Top Cat felts were a cloth covered and a rubber coated flocked material. I assume when you say a stainless bead, you are referring to a bright bead as the black bead can be stainless as well.
After all of these years, never say never, but it is interesting to hear your observation.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
