440 6pack metering plates #2559663
10/05/18 09:51 PM
10/05/18 09:51 PM
Nebraska
4406bbl Offline OP
4406bbl  Offline OP
Nebraska
Looking in the Holley catalog it shows a #34 front plate to have .029 idle hole, .052 main hole, and #35 to have .029 idle and .071 main. I have 4 #34 and 6 # 35 plates here and the 34 has.036 idle, about .090 mains, #35 has .036 idle and .089 .095 mains, all are undrilled as you can see reamed holes with plating, I take it modern plates will no longer work, or catalog misprint. Common sense tells me a .052 will not feed a 1-3/4 bbl, so what is correct for stock.
Re: 440 6pack metering plates [Re: 4406bbl] #2563036
10/12/18 06:17 PM
10/12/18 06:17 PM
Missouri
Big_E Offline
Big_E  Offline
Missouri
It made my head spin when I looking for a replacement plate for my carb. There is some great info here, about halfway down, on metering plates.
http://www.moparts.org/Tech/Archive/fuel/7.html
Hope this helps.
Re: 440 6pack metering plates [Re: 4406bbl] #2563670
10/14/18 12:37 AM
10/14/18 12:37 AM
Nebraska
4406bbl Offline OP
4406bbl  Offline OP
Nebraska
I took 3 different 440 stock I think setups apart, here is what I found....
Center
64 jets
.025 squirter
6.5 power valve
.046 pvcr
.028 high speed bleed
.055 idle air bleed
.078 throttle plate hole
Front
#34 plate with .089 mains .036 idle
.038 high speed bleed
.055 idle air bleed
.043 kill bleed
Rear
#35 plate .086 diaphram side, .093 throttle side, .036 idle
.078 throttle blade hole
.055 idle air bleed
.043 kill bleed
I also have a mopar tuning kit with the plates and springs from the 80s and it has the same 34 and 35 plates with the same size restrictions, I assume they were just stock 6bbl plates? I highly doubt these 3 setups all had their plates changed
Re: 440 6pack metering plates [Re: 4406bbl] #2563815
10/14/18 12:28 PM
10/14/18 12:28 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
All big block 70 up used the 34/35 plate,all small block used a 41 front and rear,69 1/2 used 6178 front,6180 rear.Don't remember the mmo on the 69 1/2 plates,don't have time to check but they are different.Also,"if" I remember correctly,the 69 1/2 front and rear throttle plates have no hole.
Re: 440 6pack metering plates [Re: 4406bbl] #2564012
10/14/18 07:25 PM
10/14/18 07:25 PM
Nebraska
4406bbl Offline OP
4406bbl  Offline OP
Nebraska
I can't remember if the 69.5 rear throttle blades are drilled, been decades since I had any of those, sanded a lot of sticky blades. the 69 metering plates out of a 1980s mopar kit measure as follows, I do not know how that compares to a stock set.
6178
.032 idle
.083 diaphram side
.090 throttle side
6180
.032 idle
.076 diaphram
.076 throttle
