Help with washers #2563217
10/13/18 01:56 AM
10/13/18 01:56 AM
NY
Beep Beep Offline OP
NY
I am installing a scatter shield and 4 speed transmission. The scatter shield came with grade 8 lock washers, flat washers and bolts to bolt the bellhousing to the block. Should I use the lock washers or just the flat washers? I know the factory only used flat washers. I have read that lock washers could come loose with time. Should I also use lock washers on the transmission or a star washer? Any recommendations.
Re: Help with washers [Re: Beep Beep] #2563227
10/13/18 02:26 AM
10/13/18 02:26 AM
I'd use the flat washers next to the aluminum
Re: Help with washers [Re: Beep Beep] #2563234
10/13/18 03:13 AM
10/13/18 03:13 AM
Alberta
N
NEVjr Offline
NEVjr  Offline
N
Alberta
lock washers are for the illusion of locking. if they need to have lock washers go buy the right sized nord-lock washers.
Re: Help with washers [Re: NEVjr] #2563237
10/13/18 03:50 AM
10/13/18 03:50 AM
robertop Offline
robertop  Offline
In fact technically the term " lock washer" has been superseeded by "split washer", to indicate the original description was optimistic in its effect. In my lab the term lock washer has been frown upon for many years.
Re: Help with washers [Re: Beep Beep] #2563394
10/13/18 02:35 PM
10/13/18 02:35 PM
How many of each type washers? If the same I would stack then together with the spilt lock washer between the bolt head and the flat washer on the engine bolts and use the washers with the nuts on the other side with the split washers only and use the flat washers under the bolt heads up twocents
Re: Help with washers [Re: Beep Beep] #2563728
10/14/18 02:43 AM
10/14/18 02:43 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
throw the lock washers in the trash and use flat washers and blue locktite .
degrease the bolts and thread holes with brake clean .
Re: Help with washers [Re: Beep Beep] #2563737
10/14/18 04:53 AM
10/14/18 04:53 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO I would use exactly of what the manufacture sent you, they know better than us. Why not? Lock washers work in many applications.
Re: Help with washers [Re: Challenger 1] #2563746
10/14/18 07:23 AM
10/14/18 07:23 AM
IN
ahy Offline
ahy  Offline
IN
I too would go ahead and use the lock washers. The washer itself and longer bolt stretch length can only help.
A robust joint - like that one in my experience - is not touchy and should not need thread lock.
Re: Help with washers [Re: Beep Beep] #2563748
10/14/18 08:04 AM
10/14/18 08:04 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Like stated above I would use the given hardware, because the bottom line is they wouldn't give it to you if not needed. Why because it cost them money! In the event of failure guess where the investigation would begin. One last thing I would call the manufacturer with the question and let us know what they say.
Re: Help with washers [Re: Beep Beep] #2563749
10/14/18 08:09 AM
10/14/18 08:09 AM
P
Porter67 Offline
Porter67  Offline
P
Flat washer then smaller lock washer is what I do but then again on that area what was oem... bolt with flat washer.
Thanks guys, you have just killed a lifes long belief that lock washers that worked as named since ive never had a nut come off that had a good new lock washer on it.
Ive seen lockwashers that have lost there spring (went flat).
Now im questing everything in life.
