Is it the Sure Grip going out.....
#2563641
10/13/18 11:57 PM
10/13/18 11:57 PM
Posts: 8,130 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Today I had a buddy fly in from out of town. We had the Cuda loaded with 4 pax. It felt different on the unshift, not like a 500lb difference kind of like the clutch was little soft on upshift but you know it's not the clutch.... I then rotated the tires. Just as I finished this service a newer Stang comes along. We "admired" the Mustang who was "admiring" us, we ended up impressing him more than he impressed us . I still knew we had more he would have liked normally it was just seemed to be lacking all of a sudden. It was falling short. I drove it again by myself hr's later it seemed ok until I left a light and maybe let out the clutch hard, I almost thought I dropped the drive shaft. It did nada. It gave out completely. If I tried to drive/left/accelerate real soft staying under 1500 rpm it "broke free" or let go. Sounded like the banging upon accel attempts/failures came from the diff.
Re: Is it the Sure Grip going out.....
[Re: UCUDANT]
#2563648
10/14/18 12:09 AM
10/14/18 12:09 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If a Sure Grip quits griping it acts like an open differential.
Sounds like something broke and not the SG being wore out.
[Re: UCUDANT]
#2563707
10/14/18 01:41 AM
10/14/18 01:41 AM
RapidRobert
Sounded like the banging upon accel attempts/failures came from the diff. X2 (what Supercuda said), time to pull the pig.
[Re: UCUDANT]
#2564101
10/14/18 10:08 PM
10/14/18 10:08 PM
Supercuda
About to go away
About to go away
up yours
I once swapped the gears on an 8.8 that had a clutch type limited slip. Every ear was tore off the discs and nary a sound. No limited slip action either.
[Re: Cuda340]
#2564619
10/15/18 10:23 PM
10/15/18 10:23 PM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Spider gears in the sure-grip unit could have broke teeth off as well. Thanks all, I suspect mechanical damage. It could be the centerforce clutch but I didn't hear or feel anything up front or through the pedal. I won't have time to look at it tonight, I have to take my buddy to the airport shortly. I'll try tomorrow, or it will have to wait until Saturday.
[Re: UCUDANT]
#2567069
10/20/18 09:36 PM
10/20/18 09:36 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
I was trying to wrap my head around how the diff would become "open" when it the sure grip tried to couple both axles..... the bolts that hold the halves of the suregrip unit together are coming out (if they are not actually broken too). The spider gear shows some damage as well. My 741 3.91 gears are in great shape thank goodness since they don't make them. Holy sheet! Can you post a pick? Sounds like the whole diff unit is trash.
