Re: drilled and slotted brake rotors?
[Re: 68DART360]
#2563467
10/13/18 05:26 PM
10/13/18 05:26 PM
Posts: 22,695 Bitopia
jcc
Bitopia
The "drilled" is in almost all cases, including yours, a big no no, slotted does have some upsides. I don't see how either improves any potential warping issues
[Re: jcc]
#2563480
10/13/18 05:51 PM
10/13/18 05:51 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The "drilled" is in almost all cases, including yours, a big no no, slotted does have some upsides. I don't see how either improves any potential warping issues What warps them? Heat Maybe the drilling and slotting does do something.
[Re: 68DART360]
#2563489
10/13/18 06:15 PM
10/13/18 06:15 PM
Posts: 4,792 Castlegar, BC, Canada
That AMC Guy
I warped a set of Power Stops. It took 5 years, but I still managed. They must use virgin steel or some kind of coating because 5 years later, the rotor hats still showed no signs of rusting.
Drilling/Slotting is overkill for most street cars. As stated above, slotting has some mild benefit, but only in more heavy duty applications. Slotting does keep pad glazing to an absolute minimum.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: topside]
#2563853
10/14/18 02:03 PM
10/14/18 02:03 PM
Posts: 19,310 north of coder
moparx
You'd have to absolutely try to melt the rotors to warp them; it's the uneven transference of pad material that causes that sensation. The "real" guys - road racers - that I'm seeing at the track use slotted rotors, not drilled. The slots help with the off-gassing & transfer of pad material. i agree about the pad material transfer. i know i'm not the average guy, as i turn my own rotors. it takes a long time to get the "warped" sensation, but when chucked up in my lathe, there is usually no more than a couple thou wear from new [i always record the new, out of the box, thickness]. after a .003 cut, back on they go for many, many more miles. having a lathe at home is great ! [getting to it is another matter, however. ]
