Re: Help with washers
[Re: Beep Beep]
#2563227
10/13/18 02:26 AM
10/13/18 02:26 AM
RapidRobert
I'd use the flat washers next to the aluminum
[Re: Beep Beep]
#2563737
10/14/18 04:53 AM
10/14/18 04:53 AM
Challenger 1
Cincinnati, Ohio
I am installing a scatter shield and 4 speed transmission. The scatter shield came with grade 8 lock washers, flat washers and bolts to bolt the bellhousing to the block. Should I use the lock washers or just the flat washers? I know the factory only used flat washers. I have read that lock washers could come loose with time. Should I also use lock washers on the transmission or a star washer? Any recommendations. IMO I would use exactly of what the manufacture sent you, they know better than us. Why not? Lock washers work in many applications.
