B versus RB passenger side motor mount lug spacing?
#2563046
10/12/18 07:03 PM
10/12/18 07:03 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
I'm in the middle of trying to break in the cams on two different RB motors, one is a 1976 440 motor home block and the other one is a 1972 413 C.I. H.D. truck industrial block. I borrow a friends engine run in stand to do this and he used a piece 7/16 I.D. thick wall tubing to use a single 7/16 bolt to go through the upper motor mount lugs, if fit fine on a 400 motor I ran on this stand two months ago but it won't fit on either of these two blocks due to it being to long for them on the passenger side I'm going to use a grinder to reduce the over all length of the tube on that side, the other side fits fine I did measure two 400 blocks and they are a lot wider between the lugs than either of the RB blocks Any one else run into this type problems on the B and RB blocks
Re: B versus RB passenger side motor mount lug spacing?
[Re: Cab_Burge]
#2563060
10/12/18 07:28 PM
10/12/18 07:28 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
They talk about that here, I think this is what you are looking for. CLICK HERE
[Re: Stanton]
#2563392
10/13/18 02:31 PM
10/13/18 02:31 PM
Cab_Burge
The engine mounts will fit all the blocks, the O.D. remained the same The I.D between the RB lugs got narrower, evidently, when Ma Mopar increased the thickness of them All three 400 blocks I checked are a lot narrower I.D. than the two later cast RB blocks are
[Re: Cab_Burge]
#2563589
10/13/18 10:08 PM
10/13/18 10:08 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
The ears are thinker on 75 and later blocks but the mount goes on the back side of the ears so that does effect the mount. Just need longer bolts On my 72 SSP I removed a 68 383 and installed a 75 440 using the same mounts with longer bolts.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
