1968 GTX hood release lever #2562710
10/12/18 12:33 AM
10/12/18 12:33 AM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
Is a 68 GTX/Sport Satellite hood release lever the same or different as a belvedere/Satellite? The grille is different so is the lever the same or different between them? Thanks.
Re: 1968 GTX hood release lever [Re: NANKET] #2562787
10/12/18 09:24 AM
10/12/18 09:24 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Yes, they are different, currently I have a non GTX release on my GTX and it is not pretty...functional...but not pretty, sticks forward like it's got it's tongue sticking out but it's all I had, years ago I took a bird shot to the grille and had to change to a Belvedere grille which necessitated the release change also, somewhere over the years I lost the correct release, haven't been able to find one yet. Below pics shows what mine currently looks like.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: 1968 GTX hood release lever [Re: NANKET] #2562877
10/12/18 01:29 PM
10/12/18 01:29 PM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
Thanks for the photo. So is the GTX release just shorter than what you Have? Does it look the same where it mounts and the pivot area? Does it have the spring also?
Can you measure your current lever from center of pivot to end? Thank you!
Re: 1968 GTX hood release lever [Re: NANKET] #2562961
10/12/18 04:02 PM
10/12/18 04:02 PM
Weatherford, Texas
Weatherford, Texas
From the pivot to the tip it is 3 3/4 inches long, however, if I remember correctly the correct lever is designed differently so that it reaches around the grille structure in kind of an "S" shape, I looked at my buddies about 3 years ago and I think that's the way I remember it.
1968 Plymouth GTX
Re: 1968 GTX hood release lever [Re: NANKET] #2563126
10/12/18 09:34 PM
10/12/18 09:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't think the GTX/SportSat upper grille molding sticks out any less than a RR/Sat/Bel does, both are pretty flush with the hood edge.
Are you sure that's not from a '69 or '70? If I recall, the location for that release and the striker changed...
Feel free to correct me if I'm wrong here! I've run into that but it was 25+ years ago.
Re: 1968 GTX hood release lever [Re: NANKET] #2563160
10/12/18 11:24 PM
10/12/18 11:24 PM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
1970 is complete different. You release the first lever under the grille, not on top of the grille.
Re: 1968 GTX hood release lever [Re: NANKET] #2563319
10/13/18 11:53 AM
10/13/18 11:53 AM
Weatherford, Texas
Weatherford, Texas
I'm going to try and get a picture of my buddies if I can...more to follow...
1968 Plymouth GTX
Re: 1968 GTX hood release lever [Re: RapidusMaximus] #2563433
10/13/18 03:53 PM
10/13/18 03:53 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
1968
Parts Catalog shows
15-11-5
hood latch handle
R (except RP/RS) #2862007
RP/RS #2862431
1969
Parts Catalog shows
15-11-5
hood latch handle
R #2935356
