Page 1 of 2 1 2 >
#2557546 - 10/02/18 09:31 AM For Sale - Small Block Engine - 4th Quarter
moparts Offline
#2557673 - 10/02/18 12:34 PM QFT/Proform-type "950" 1.45" v 4150 Carb [Re: moparts]
BradH Offline
Loc: Valhalla... eventually
Please refer to advertisement in Race Parts for Sale: HERE!
#2557753 - 10/02/18 02:42 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
Original Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $35
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
Original Cal Custom 9" finned air cleaner top and base. No filter. $75
AC alternator bracket from a mid 70s 360. $15
Good used intake to water pump crossover hose from a mid 70s 360 with AC. $5
Mr. Gasket 1" thick carb spacer. $15
Small block passenger side biscuit motor mount bracket. $30
137 New Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
New Cloyes C-3028 small block Mopar timing chain. $25
Carb. throttle linkage stud. $10
Pair of factory small block valve covers. Not sure of year. Nice shape. $75
Alternator date coded 1965. $60
Email: gt340 @ yahoo.com
#2558099 - 10/03/18 02:50 AM Small block 273, 318, 340, 360 Weiand aluminum valve covers [Re: moparts]
Memongo Offline
Loc: Fenton, MI
Small block 273, 318, 340, 360 Weiand Aluminum Valve Covers. $100. Call Steve 810-629-1097.
Edited by Memongo (10/03/18 02:50 AM)
#2558590 - 10/03/18 07:54 PM 1973 Carter 6317S Carb [Re: moparts]
Powerflow Offline
Loc: New Jersey
This is a used carb that came off my cousin's '73 Coronet in 1976. Been sitting in a box since then. $25.00 + shipping from Freehold, NJ 07728. Best contact is via Moparts PM.
#2558752 - 10/04/18 03:04 AM Casler small block headers, fits 273, 318, 340 and 360 motor [Re: moparts]
Memongo Offline
Loc: Fenton, MI
Casler small block headers, will fit 273, 318, 340 and 360 motors. Used, in good condition. $200. Call Steve 810-629-1097.
#2558997 - 10/04/18 04:39 PM Re: 360 aftermarket truck oil pan [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
I have for sale a 360 truck oil pan. I got this pan with a bunch of other stuff that I bought a while ago. The pan is from China but looks to be made with fairly heavy metal. From the looks of it, it appears to have been installed on an engine at one time but no oil has ever been put into it so it may very well have never been used. I would like to get $45 for it plus the shipping. No dip stick or pickup though.
Edison, NJ
rider1454 at aol.com
#2559773 - 10/06/18 08:10 AM Re: 360 aftermarket truck oil pan [Re: moparts]
69swinger340 Offline
Loc: Hillsdale,Mi
70 340 long block complete from intake to oil pan. X heads and 273 rockers.
$2750 obo
Email is best. Tsawyer340@gmail.com
Jonesville, mi
*69 swinger 340 4spd *70 T/A 340+6pk 4spd
#2559831 - 10/06/18 10:29 AM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
schmitty Offline
Loc: IN
Greetings - I have a slightly used Comp Cams hydraulic roller cam with just 350 street miles - absolutely no issues. The pn 20-813-9 with the specs on the photo links below - total lift .544, .541. Comes in it's original box with the cam card. I do not have any lifters as I have already sold them. $225.00 + actual shipping. Please contact me at 260-223-0868 up until 8pm est or schmittyjsathotmail.com Thanks Moparts!!!
[img:center]https://flic.kr/p/PCue8o[/img]
[img:center]https://flic.kr/p/PCuh8b[/img]
[img:center]https://flic.kr/p/2bLsnDH[/img]
#2560761 - 10/08/18 09:03 AM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
Pale_Roader Offline
Loc: the frozen wastes...
5.2/5.9 Magnum speed parts
Crosswind Magnum swap intake (RPM Air-Gap), brand new in box.
Bullet Magnum hyd roller cam (custom), 235/245@.050, .555lift, 108 lobe sep, Designed for big lope, big power, but mild enough for an unbuilt engine, and easy on springs.
Steel shim head gaskets .215" compressed ht, 'very last pair available anywhere'.
Aluminum water pump/crank pulleys, slight underdrive.
Milodon (or Moroso?) solid (LA) engine mounts.
Dougs 453r SBM headers for B/E body (possibly others?). Older design, but still modern style that DONT go underneath suspension.
I can separate headers/mounts from the rest if you're not building a car, but i'd rather keep the rest together.
Looking for $700 USD.
Also have a Luk clutch kit for SBM, brand new in box. $160 USD
Located in British Columbia, an hour East ov Vancouver.
PM here for details.
Thanks.
#2560933 - 10/08/18 01:42 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: Pale_Roader]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
273-318-340-360 new electronic ignition/single point v8 caps and rotors
new black,aluminum insert hd ribbed cap,usa made$10ea
new,black,copperor brass insert hd ribbed cap,usa made$20 w/ a rotor
black mallory brass insert hd cap&mallory rotor$30
cowgerwilliam035@gmail.com
#2560991 - 10/08/18 03:40 PM Fresh black wrinkle powder coated MT valve covers [Re: Joesixpack]
dodge turbo Offline
Loc: Dirty Dena, Maryland
Message me for pictures. It will not let me add them
$120 OBO
Edited by dodge turbo (10/10/18 04:11 PM)
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
#2561382 - 10/09/18 11:17 AM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
schmitty Offline
Loc: IN
Greetings - I have a very lightly used Edelbrock small block mopar LA engine 273,318,340 and 360 mechanical fuel pump (pn 1720). This only has 350 street miles and works perfectly. This pump runs at 6 psi and requires no regulator. Comes with original box and bolt kit. I would like to get $100.00 + actual shipping as it sells for $160.00 new. Please contact me at 260-223-0868 up until 8pm est or schmittyjsathotmail.com Thanks Moparts!!!
[img:center]https://flic.kr/p/2bN9FC3[/img]
[img:center]https://flic.kr/p/2bN9HTW[/img]
#2562544 - 10/11/18 04:42 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
727builder Offline
Loc: Tennessee
Like new 360 Moroso 8qt deep oil pan and Pick-up tube. Was used about 2 months on 408. Was too deep for the customer. Never bottomed out. Cost over $300 from summit. Take $225 with free delivery to the lower 48.
Can pm me here, Or call or text for quicker reply.
Can send more pics...
Carl 423-402-6752
Thanks Moparts!!
#2562762 - 10/12/18 01:01 AM PCE2311-1.6 ALUMINUM ROCKER ARMS Small Block Mopar CHRYSLER [Re: moparts]
Furys Offline
Loc: wi
new in package 150.00 and shipping,paypal money order check email benfrank@charter.net
Brand: Procomp Electronics
Part Number: PCE261.1032
Part Type: Rocker Arms
Rocker Arm Mounting Style: Shaft
Rocker Arm Ratio: 1.6
Rocker Arm Style: Full roller
Shaft Diameter (in): 0.875 in.
Shims Included: No
Self-Aligning: No
Rocker Arm Body Style: Standard
Rocker Arm Material: Aluminum
Rocker Arm Finish: Red anodized
Quantity: Sold as a kit.
Procomp Electronics extruded aluminum and stainless steel shaft mount rocker system includes steel shafts with pedestals. All rockers feature large roller tips. For extreme high performance applications. They not only unleash horsepower, but they also lengthen valvetrain component life and reduce wear and tear on valve stem tips. These rockers are precision-machined to ensure consistency and ratio accuracy and have a great looking anodized finish.
Edited by Furys (Yesterday at 07:45 PM)
#2563864 - 10/14/18 12:27 PM Small Block 415Ci, part or complete [Re: moparts]
Kid-Dart Offline
Loc: Michigan
I am testing the waters, I am going GenIII and need to sell before I buy new motor. Open to trades pending what you have. Only want to trade for Gen III motor parts.
Prefer Complete motor(Running)
360 Block
Cast Crank (4 inch Stroke)
Eagle SIR Rods
Wiseco Flat Top Pistons
12.0 to 1 Compression
Manley High Volume Oil Pump
8 qt. Oil Pan
SFI approved Balancer
Complete 360-1 Indy Heads (Modern just went over the heads and did guides and springs)
Molly Push rods
360-1 Indy Intake
Indy Solid Hot Street Cam 250/260 dur @.050” 532/555 Lift
1.5 Indy Offset Rocker assemblies
[list]
[*]Complete Motor $5500.00
[*]Short Block $2500.00
[*]Heads(w/Rocker assemblies), intake, valve covers $3000.00
[*]TTI 1 7/8 ceramic Headers 3 inch Collectors(not dented up) with O2 Bung ($400.00)
would really like to sell complete.
PM me for info and motor is in the car and runs and runs good
74 Dart Sport Best to Date 10.82 in the 1/4
#2563896 - 10/14/18 01:27 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: schmitty]
moparjohn Offline
Loc: N.W. INDIANA
Recently I have finished bead blasting and priming my extra water pump pullies. I am starting to look up the ones that have part numbers. So I have found a 2951836 that is for 1970 Challenger T/A's and AAR CUDA's with the 340 engine. The price is $40.00 plus shipping. If your interested contact me at: moparjohn@frontier.com with your zip.
If you are looking for a water pump pulley let me know the diameter and how deep. I have many to choose from.
Thanks!
#2564245 - 10/15/18 02:01 AM Holley 4150 carburetor 750 double pumper [Re: moparts]
Memongo Offline
Loc: Fenton, MI
Holley 4150 carburetor 750 double pumper with electric choke, used, $250. Call Steve, 810-629-1097.
#2564298 - 10/15/18 08:41 AM Re: QFT/Proform-type "950" 1.45" v 4150 Carb [Re: BradH]
gtxblu Offline
I have a complete 1966 273 engine that is seized up. Pulled it last week out of my satellite. It is missing the carb and one exhaust manifold. First $100.00 takes it. 1-734-775-0738. located outside of detroit.
#2564369 - 10/15/18 11:01 AM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
LemonTwiist Offline
Loc: Mechanicsburg, PA
FOR SALE: Used metering block #6512 #4780. It still has the power valve, jets, and needle adjusting screws. The part numbers have been sanded off, but can still be seen in the casting. PRICE $35.00 Plus $6.00 postage
Edited by LemonTwiist (10/15/18 11:02 AM)
Page 1 of 2 1 2 >
25,532 Registered Members
193,976 Topics
hood
by GVH
10/18/18 06:45 AM
1970 Plymouth Road Runner Blue
by tomsjack
10/18/18 03:55 AM
New Cadillac XT4 Commercial . . . Mopar showing !
by a12rag
10/17/18 11:43 PM
draining a 42re pan
by rhad
10/17/18 10:52 PM
