Page 4 of 5 < 1 2 3 4 5 >
#2561675 - 10/09/18 09:30 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
ARP #245-4307 12pt. Head Studs B1 Heads, NEW, $200 shipped
PayPal (+3%) & USPS Money Orders accepted
email: mgray0918@verizon.net or pm me thru Moparts
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
#2561677 - 10/09/18 09:32 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
Comp Cams BB Mopar Solid Roller, three bolt, older camshaft, used, very good condition, no cam card but here are the specs per Comp:
Intake: 288 @.050 / .483 lobe lift
Exhaust: 316@.050 / .480 lobe lift
114 lobe separation
Comp Cams Roller Lifters, .904 dia., centered, used, all rollers turn freely
Triple Springs, titanium retainers, locks (15), lash caps (8) (unknown brand, I assume Comp)
All came from an engine I purchased and parting out. Package deal all for $500.00 shipped
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
#2561678 - 10/09/18 09:32 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
B1/MC valves, 2.400" x 5.500" x .3415 stem titanium intake (6) used, 1.780" x 5.400" x .3415 stem stainless exhaust (6) used, $400 for all shipped
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
#2561679 - 10/09/18 09:33 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
Stroud Parachute Parts:
#472 Large Pilot (420-430) new, $70
#473 Large Chute Pack (420-430) new w/ used Chute Pack Plate, $70
#4063 Large Chute Bag (420-430), new, $40
#473 Large Chute Pack, used, $35
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
#2561681 - 10/09/18 09:33 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
Misc. Nitrous:
Induction Solutions 1/4 Turn Valve #19705, w/ 6AN fittings. mounting tab, new, SOLD
4" dia. Nitrous Pressure Gauge, used, SOLD
4ft. 6AN Line,NOS, used, SOLD
2ft. 6AN Line, IS, 90° x str., new, $42
1ft. 4AN Line, NOS, used, $15
8in. 4AN Line, NOS, used, $12
Edelbrock #72281 WOT Switch, 4500 carb, new $30
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
#2561683 - 10/09/18 09:34 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
Jegs 2 1/2lb. CO2 Bottle #60207, New, SOLD
Jegs CO2 Regulator#60200, New, $65
Jegs CO2 Shifter for B&M Pro Bandit #62350, New, $105
Jerry Bickel Chrome CO2 Bottle Mount #JBRC1105, used, SOLD
B&M Shifter Cable Extension #80323, New, $45
B&M Shifter Cable Bracket #70460, New, #70460, $11
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
#2561685 - 10/09/18 09:35 PM Re: For Sale - Race Parts - 4th Quarter [Re: Plumb Wired]
Plumb Wired Offline
Loc: Blue Ridge, VA
417 R3/W8
Mopar R3 9.20” deck, 48,° siamese bore block w/ 50mm roller bearing cam tunnel
Currently 9.15” deck, 4.185” bore
Callies 3.79” Dragon Slayer forged crankshaft
King main bearings
GRP 1200 Pro Series nitrous rods 5.90” length
Clevite rod bearings
Custom Diamond flat top nitrous pistons, .043” / .043” 3mm ring grooves (2 spares)
Total Seal Hellfire rings
Custom LSM/Monte Smith nitrous camshaft, 2/3, 4/7 swap
Isky Red Zone .903” lifters
Bushed lifter bores
Weber belt drive
MSD Super Conductor spark plug wires
ATI balancer
Moroso mandrel
Moroso 3 vane vacuum pump
MSD HVC-2 coil
MSD crank trigger
Meziere electric water pump
Custom ¼” aluminum motor plate
Custom Charlie’s aluminum oil pan ( will fit A-Body with tubular K- member and rack or tube chassis)
Stock Car Products single stage external oil pump
CV Products remote oil filter mount
Mopar W8 Craftsman Truck 15° Cylinder Heads (Spintron heads purchased from Kent Ritter)
Originally set up by Ryan Johnson, SDSS, additional port work & valve job by Brett Miller
Titanium valves
T&D rockers
Smith Brothers pushrods (2 spares)
Manley Nex Tek valve springs
Cometic head gaskets
Custom billet W8 valve cover by Alan Jones
Hogan's sheetmetal intake w/ Monte Smith single fogger & rear pull carb linkage (also have Hogan's single four top)
(2) Pro Systems 1120 Nitrous Pro-IV carbs
Reher Morrison reversion plates
Magnafuel fuel log w/ Magnafuel flow thru regulator for carbs, Holley 12-803 for N2O
Brown & Miller crimped hose & fittings
ARP fasteners
Engine was originally built by Ryan Johnson, SDSS in 2009, freshened by SDSS in 2011. In the fall of 2011 we had a fire in our 69 Dart. The heads were sent to Brett Miller in Jan. 2012 were Brett discovered that the heads although “new” Spintron time only heads they were two slightly different heads. Brett improved the flow of the heads and cleaned up the valve job. The engine sat until the spring of 2016 when I took it to Matt Hensley @ at Hensley Performance, Knoxville, TN where Matt went completely through the engine and re-assembled adding the Weber belt drive and the sheetmetal intake.
I have documentation of all work done on this engine. I will only share detailed specs with a serious buyer!!!
This engine ran a best of 5.20’s at 3000 + ft. DA in our 69 Dart. The car weighed a little over 3000lbs. with ladder bar rear suspension, Liberty Equalizer 5 speed trans. w/ a dual disc clutch, 420 intake & Dominator. We never saw the true potential of this combo on the nitrous. The car was built to run both n/a in Gear Jammers and heads up in the local small tire class. The 3.06 first gear and 4.10 rear gear (12.54 SLR) made it difficult to get off the starting line on 28 x 10.5’s. In a good chassis and with the right SLR this combo should run bottom 5’s or high 4’s.
$17,500 firm, I do not have to sell!
No tire kickers or picture collectors. Please don't waste my time or yours if you are not a serious buyer!
Also available:
Reid BH-060 SB powerglide bell $300
Gebler stainless ceramic coated headers to fit a Bickel Dodge Dakota PST chassis (NHRA flange) $1200
SPD W8 M88324 mid steel 1 7/8" exhaust flanges (Craftsman Truck flange) $200
* will not sell these items until the engine sells and the buyer does not want!
email: mgray0918@verizon.net or pm me through Moparts
Edited by Plumb Wired (10/09/18 09:37 PM)
RIP Monte Smith
aka: OutlawFish
#2562064 - 10/10/18 04:20 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
schmitty Offline
Loc: IN
Greetings - I have a Holley 750 street HP carburetor list # 82751 for sale. Mechanical secondaries. Very clean and low mileage out of my personal street car which I'am returning to stock form. Carb is all stock and ready to bolt on and use. I will include a new base gasket with it and the clean original box from when I purchased new. $400.00 + shipping. I would be interested in a pair of non pitted very clean factory lower control arms with sway bar tabs for 1968-1972 "a" body as a partial trade. Best to call 260-223-0868 up until 8 pm est or schmittyjsathotmaildotcom Thanks Moparts!
[img:center]https://flic.kr/p/2bQv93L[/img]
[img:center]https://flic.kr/p/2aP6uzG[/img]
#2562154 - 10/10/18 07:53 PM Re: For Sale - Race Parts - 4th Quarter [Re: schmitty]
birdtracker Offline
New aluminum big block water pump housing with polished water pump and electric drive set up. $250 plus actual shipping. Located north of Dayton Ohio. pm here if interested. Thanks for the ad Moparts. Birdtracker
#2562758 - 10/12/18 12:54 AM PCE2311-1.6 ALUMINUM ROCKER ARMS Small Block Mopar CHRYSLER [Re: moparts]
Furys Offline
Loc: wi
new in box 190.00 and 18.00 shipping paypal money order check
Brand: Procomp Electronics
Part Number: PCE261.1032
Part Type: Rocker Arms
Rocker Arm Mounting Style: Shaft
Rocker Arm Ratio: 1.6
Rocker Arm Style: Full roller
Shaft Diameter (in): 0.875 in.
Shims Included: No
Self-Aligning: No
Rocker Arm Body Style: Standard
Rocker Arm Material: Aluminum
Rocker Arm Finish: Red anodized
Quantity: Sold as a kit.
Procomp Electronics extruded aluminum and stainless steel shaft mount rocker system includes steel shafts with pedestals. All rockers feature large needle bearings and roller tips They not only unleash horsepower, but they also lengthen valvetrain component life and reduce wear and tear on valve stem tips. These rockers are precision-machined to ensure consistency and ratio accuracy and have a great looking anodized finish.
Edited by Furys (10/12/18 12:55 AM)
#2562890 - 10/12/18 11:49 AM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
LimeRT Offline
Loc: NE
Edelbrock aluminum 60197 NHRA 84cc heads,2.14/1.81 competition stainless valves,45 deg seat,30 degree backcut on intakes,PAC springs,10 degree comp retainers and locks. Used but just freshened ready to bolt on. $1250
Hooker 5320 2 1/8" adjustable drag headers powder coated black $550
please text 4023406055 if interested thanks
#2562898 - 10/12/18 12:06 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
LimeRT Offline
Loc: NE
New small block M1 single plane intake 4452893 $200
used proform small block roller rockers $125
Custom bullet solid roller 3 bolt BB vacuum cam 270/279 240/244@ .050 .638/.587 lift w 1.5 rockers couple passes like new $200
#2563604 - 10/13/18 08:33 PM Purple Shaft Cam and Lifters - 284/484 [Re: Plymouth340]
clovis Offline
Loc: Kentucky
I have a new 284/484 purple shaft hydraulic cam and lifters-single bolt. It was installed but never ran. I am also including a new timing chain set. $250 plus shipping. Just the cam and lifters are $375 new from Summit and a little more than that from Mancini.
108 LSA
Events at @ .050
Duration 239 (measured 236)
IVO 11 EVO 47
IVC 48 EVC 12
I also have a set of single springs, retainers, 15 locks and umbrellas seals (all new) that I can include in the package for another $100. I am not sure if they are 7 or 10 degree locks. I am going to assume 7.
All these parts came off a complete newly assembled engine I bought. The motor was assembled but never ran. I am going with a more aggressive solid cam is the reason for sale.
For $350, I’ll include everything listed above and free shipping to the lower 48 United States.
Edited by clovis (10/14/18 07:12 PM)
'75 Duster 451 906/590/2-660 10.75/126
New combo-Stage VI/590/1050 6.23/111 9.82/135
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
#2563913 - 10/14/18 02:00 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
CV Products lightweight remote oil filter mount. Very nice condition, we mounted it on the dyno and then decided not to use it. This one uses the larger 13/16 thread filter. I'll include a brand new Wix filter with the mount. $100 plus shipping for both. PayPal preferred. PM me on the board.
#2563916 - 10/14/18 02:02 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
SOLD - Moroso 2 qt breather can. This setup works great on a big engine. Run a #12 from each valve cover to this can and you shouldn't have any issues with oil blowing out of the valve cover breathers. $60 plus shipping. Nice condition. I used it a few times on the dyno with my race engine but do not need it any longer. PayPal preferred, PM me on the board.
Edited by AndyF (10/15/18 04:31 PM)
#2563917 - 10/14/18 02:03 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
Moroso 62600 solid transmission mount. Somewhat of a universal design. New in the package but it has been sitting on my shelf for a few years. $15 plus shipping. Paypal preferred. PM me here.
#2563919 - 10/14/18 02:04 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
SOLD - Poly transmission mount. I think this is a prothane design. $30 plus shipping. Mount is brand new, I used it for mockup then decided to use something else. Paypal preferred. PM me on the board.
Edited by AndyF (10/15/18 12:53 AM)
#2563920 - 10/14/18 02:05 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
SOLD - Oil pan pickups. $25 each or $40 for both. Build your own pan. I think these came from Milodon but I don't remember. I've had them sitting in a drawer for a few years and decided I wasn't going to use them. PayPal preferred. Pm me here.
#2563923 - 10/14/18 02:08 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
SOLD - Meziere SB electric water pump. I used this on my big block race engine a few times on the dyno. Very nice shape, includes the billet inlet fitting. $250 plus shipping from OR. PayPal preferred. PM me here.
Edited by AndyF (10/15/18 04:32 PM)
#2564230 - 10/15/18 01:05 AM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
Holley throttle body for port injection EFI. 2000 cfm, Dominator flange. Should support well over 1000 hp on a NA engine. I used it on my 514 race engine at 900 hp without any issues. Very nice shape, only used a few times. $600 plus shipping. PayPal preferred, PM me on the board.
25,533 Registered Members
193,976 Topics
Are vacuum advances rebuidable?
by Moparpete
10/18/18 08:22 AM
EFI conversion reliability
by moparmarks
10/18/18 08:21 AM
hood
by GVH
10/18/18 06:45 AM
1970 Plymouth Road Runner Blue
by tomsjack
10/18/18 03:55 AM
