Page 1 of 3 1 2 3 >
#2557489 - 10/02/18 08:53 AM Mopar Transmission For Sale - 4th Quarter
moparts Offline
#2557518 - 10/02/18 09:12 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
64dodge572 Offline
Loc: Ohio
BREWER’S PERFORMANCE, INC, Chrysler 4-speed transmission and parts
specialists.
1970 B-body console pistol grip levers back in stock $349.95:
http://www.brewersperformance.com/proddetail.php?prod=PG610C
NEW! Speedometer pinion gears for 1966 & later A833 904 and 727 transmissions using long stem style gears, available in 34 35 36 37 38 39 40 41 42 and 43 tooth $44.95 each.
http://www.brewersperformance.com/products.php?cat=277
THE MOST COMPREHENSIVE, UP-TO-DATE WEBSITE FOR ALL YOUR 4-SPEED RELATED NEEDS:
NEW: Hurst licensed pistol grip shifter, fits 2009-up Dodge Challenger 6 speed, including the new Hellcat. Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. Shifter can be modified for shorter throw, by cutting off the bottom mounting screw/hole. $249.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG-CHALL-6
NEW: Cast iron bearing retainer for 1968-72 18 spline transmissions with 308 front bearing, 4.805" outside diameter, 4.16" bolt circle, replaces cast #C97621/2801892 original retainers, and Mopar Performance P4529697. Gasket and seal included.
http://www.brewersperformance.com/proddetail.asp?prod=BR-621C
NEW: Pistol grip shifter, fits new Dodge Challenger/Charger automatics (and all LX platform cars). Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. $149.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG112
VISIT OUR NEW RESTORATION PARTS SECTION, SAME GREAT SERVICE AS OUR 4-SPEED PARTS:
http://brewersperformance.com/store.asp
WE BUY 4-SPEED TRANMISSIONS & PARTS
NEW LOWER PRICE--Rebuilt OE factory Hurst shifter mechanisms from $149.95
NEW PARTS—We now stock all service parts for Hurst Shifters, see our website:
http://brewersperformance.com/products.asp?cat=132
We are the manufactures of the following parts:
Reproduction 1968-69 Console shift handles for A & B body cars from $241.57
1970 Column/reverse interlock linkage kits for B-body big block and E-body big/small block cars $249.95
Correct 1970 B-body console boot with rectangular opening for pistol grip shifter $89.95
New Big Block bellhousings, heat treated aluminum $349.95, steel dust covers $99.95
67-76 A-body and 66-74 B & E body ballstud frame brackets $39.95 ea
Torque shafts (Z-bars) for all popular A B & E body cars $89.95 ea
A-body big block clutch linkage kits, Hydraulic slave kits also.
Clutch pedal to torque shaft rods A, B & E bodies $59.95
Clutch pedal over center spings $49.95
Clutch pedal over center spring retention pins $19.95
Small block 10.5” bellhousing starter seal $39.95
Big block 10.5” & 11.0” starter shims/seals $12.95
Clutch pedal support firewall stud brackets for 66-74 B & E bodies $19.95 ea
Shifter linkage rod sets for A B & E body cars $124.95-$149.95 set
Transmission linkage operating levers for A B & E bodies $54.95-$59.95 set
Billet steel bearing retainers for 18 spline 4-speeds $129.95
Billet aluminum shifter mounting plates for A, B & E bodies, with all hardware $59.95
Clutch fork pivot brackets $19.95-$29.95
Synchronizer strut keys for 68-9 4-speeds $10.95 ea
Hurst shifter mechanisms to retain your stock Inland shift lever $299.95
Transmission side cover wiring clips, retains backup light wiring $8.95 pair
Conversion torque shaft kits for 10.5” small block bellhousings into 1963-66 A-body cars
We also stock:
New Hurst shifter mechanisms from $219.95
Bearing and seal kits from $99.95
Synchro rings $49.95 set/4
Restored factory Hurst shifter levers from $249.95
New pistol grips from $244.99, lenses, grips & bezels available
Shifter boots from $59.95
Shifter boot bezels from $29.95
Reverse indicator lamps $89.95, wiring harnesses from $29.95
Woodgrain shifter ball $39.95
Rebuilt transmissions from $1299.95
Polyurethane transmission mounts from $69.95
Speedometer cables from $39.95, speedometer pinion gears from $24.95
Torque shaft service kits from $59.95
New flywheels from $199.95, cast crank applications available
Bellhousings for all applications
Centerforce and McLeod clutch packages from $332.07
From one part to complete 4-speed conversion packages, we stock it all! Same day shipping on orders received by 2PM.
We accept Visa/MasterCard/Discover.
BREWER’S PERFORMANCE, INC.
10510 State Route 571
Laura, Ohio 45337
Phone:937-947-4416 or 937-698-4259 9am-5pm Monday-Friday
Fax:937-947-4419 24-7
#2557589 - 10/02/18 10:14 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Goat330 Offline
Loc: Randolph, Ohio--N.E. Ohio
I have several slant 6 904s from early 70s darts laying around $20 each.I also have SB 904 cores $25 each. Also have a couple of small block 727s for cores $30 each.Local pick-up only,Bill at wmemore@aol.com or PM,Thanks for the ads Moparts!
#2557590 - 10/02/18 10:15 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Goat330 Offline
Big block pushbutton T-flite with 62-64 trunnion type output shaft. have the parts to put together or a bare case, $50. Local pick-up only,Bill at330-947-3362 or wmemore@aol.com Thanks for the free ads Moparts!
Edited by Goat330 (10/02/18 12:34 PM)
#2557598 - 10/02/18 10:24 AM A,B & E 23 & 18 Spline 4 Speeds for Sale [Re: Goat330]
blewbyu Offline
Loc: Florida
I have 3 different 4 speed transmissions I just have rebuilt for sale with a guarantee. I am cleaning out my shop of items that I do not plan on using in the future. See the list below of what I have available:
A Body True 23 Spline 4 Speed not an over drive. I believe it is originally from a 69 Dart with date code 2821/April 18-1969 Vin 9B370711 $1395.00 plus shipping
B & E Body True 23 Spline dual shifter pad 4 speed not an over drive. Not sure what it was originally from but date code is 3006/Oct 20-1969 vin 0B169011 $1475.00 plus shipping
B Body True 18 Spline Single shifter pad Hemi 4 Speed. I believe by the vin number it came from an A12 Roadrunner as it falls within several know A12 RR. Date code is 2856/ May 23-1969 $2500.00 plus shipping Also have a dual pad shifter tail shaft in case you want it for a 70-up B & E car for Addition $250.00. SOLD
blewbyu2bad@aol.com
Edited by blewbyu (10/25/18 01:25 PM)
#2557602 - 10/02/18 10:25 AM Re: A,B & E 23 & 18 Spline 4 Speeds for Sale [Re: blewbyu]
blewbyu Offline
Loc: Florida
blewbyu2bad@aol.com
Vin pics
Edited by blewbyu (10/25/18 01:26 PM)
#2557628 - 10/02/18 11:18 AM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
For sale: Big block 4-speed bell housing #2468372, bell housing inspection cover, big block clutch fork, big block A-body z-bar, new big block A-body z-bar bellhousing and frame ball pivots, new ball stud seal, 2 new clutch linkage washers and a new throwout bearing as shown in the pictures. The bell housing and clutch fork have been sand blasted and primed. The inspection cover has been sand blasted and painted gloss black. The z-bar has been blasted and primed since the picture was taken. I also have an 11" flywheel that is included that is not shown in the picture. $750 for everything. Only selling as a package. I would prefer not to ship but will do so at buyer's expense. gt340 @ yahoo.com
#2557722 - 10/02/18 01:59 PM 1970 440 HP 727 PK 3410670 [Re: moparts]
davesmopars Offline
Loc: cheshire, ct
Rebuilt with new Converter
1550.00 plus shipping
#2557740 - 10/02/18 02:22 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
johnnyd Offline
Loc: Boston, MA
used powerglide transbrake solenoid. both of these are by TCI. about 2 seasons on each. ***SOLD*** thanks Moparts!
Edited by johnnyd (10/15/18 11:03 AM)
#2557878 - 10/02/18 05:25 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
mrrandyj Offline
Loc: CT
727, 518 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 727, 518, 46RH, and 46RE transmission. The rear servo piston is a 1-piece design that replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. The piston is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. It comes in a kit with a heavy duty stainless steel return spring that will eliminate 1-2 shift overlap, a new seal, and a .075 extra thick retainer made from stainless steel that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This kit fits 67 and newer 727, 518, 618, 46RH, and 46RE transmissions. I also have a kit that fits the early 62-66 727’s. The price for either rear kit is $75.00.
MADE IN THE USA!!!
There is a $8.00 shipping charge per order. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
#2557879 - 10/02/18 05:26 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE DUAL RING FRONT BILLET SERVO KIT
Dual ring billet front servo kits for 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. The front servo is responsible for applying the front band during the 1-2 shift. This servo is based off of the highly desired 71 and earlier Chrysler “small pin” servo that is ideal for use in performance transmissions, only this one is much better. The piston and cover are CNC machined out of solid 6061 billet aluminum and the shaft is CNC machined from prehardened 4140 steel. There are 2 return springs custom made out of stainless steel that will help eliminate the 2-3 shift overlap that these transmissions are known for. There is a custom made metal gapless sealing ring that seals the cover to the case, and also a o-ring in the cover that seals it to the shaft. The o-ring and the gapless ring work together to eliminate internal leakage and allows more oil get to 3rd gear where it is needed most. The piston has 4 total sealing rings, doubling the sealing capacity of the original Chrysler servos. This is a ready to install kit, all the sealing rings and springs are included. The price for this kit is $125.00 plus $8.00 for shipping.
100% MADE IN THE USA
If you have any questions or to place an order my email address is mrrandyj@aol.com
#2557880 - 10/02/18 05:27 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
904 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 1967 and newer 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE Dodge Plymouth Chrysler Jeep or AMC transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1 piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the piston, a heavy duty return spring that will help eliminate the 1-2 shift overlap, a new seal, and a .075” extra thick stainless steel retainer that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This is a complete ready to install kit, no extra parts are needed and it is 100% Made in the USA. The price for this kit is $75.00. There is also a $8.00 per order shipping charge.
#2557881 - 10/02/18 05:29 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
BILLET DUAL RING ACCUMULATORS
These will fit just about any torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RE, and 48RE, almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These are a great upgrade for all the 727s and 904s and are also perfect for replacing the plastic accumulator that Chrysler switched to in the late 80s. The plastic accumulators are known for cracking and causing problems in performance transmissions. I have done these 2 different ways: First is an exact stock replacement, this one will accept all the stock springs whether they go between the case and the piston or the piston and the valve body. These are perfect for the turbo diesel guys that have tighter aftermarket torque converters, or for the person doing a stock type rebuild on a gas transmission. Second is with a built in blocker rod that will stop the accumulator from moving in the bore and firm up shifts. No need to cut down round stock and make a blocker rod anymore, I did it for you. Comes with all 4 sealing rings. The price on these are $45.00 each. There is also a $8.00 shipping and handling charge per order.
These are 100% Made in the USA. If you have any questions or want to place an order email mrrandyj@aol.com
#2557882 - 10/02/18 05:31 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
47RH 47RE and 48RE Billet Rear Servo Kit
High performance, low/reverse billet rear servo kit for a 1994-2007 47RH, 47RE, and 48RE Dodge Cummins Turbo Diesel and SRT10 Ram truck automatic transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the aftermarket shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1-piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the billet aluminum piston, a heavy duty stainless steel return spring that will eliminate the manual 1-2 shift overlap, a new seal, and a extra thick CNC machined billet steel retainer that will not bend around the retaining ring and pop out of the case like the factory retainers do. This is a complete ready to install kit, no extra parts are needed. The price for this kit is $90.00 plus $8.00 for shipping.
#2557891 - 10/02/18 05:38 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE FRONT BAND STRUTS AND BILLET BAND ANCHORS
Heavy duty, double thick, billet steel front band strut and billet front band anchor for a Dodge, Plymouth, Chrysler, or AMC 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. This fits from the 1962 727 transmission, all the way up through the 2007 ½ Cummins Turbo Diesel 48RE, and everything in between. The OEM Chrysler front band struts are prone to bending, and the OEM band anchors are known for breaking in high performance and heavy duty applications. The band strut is CNC machined from 1/4” thick steel, which is twice as thick as the factory strut and it is zinc coated for corrosion protection. The band anchor is also CNC machined from billet steel. Both are made in the USA. The price is $25.00 each, and includes shipping anywhere in the USA.
I also have the struts for a 904 transmission, same price
Email mrrandyj@aol.com
#2558742 - 10/04/18 01:30 AM Pushbutton 727 Transmission O-Ring Seal Kit [Re: mrrandyj]
whuston383 Offline
Loc: Glendale, CA
These are Nitrile (NBR) sourced from an aerospace supplier. This kit replaces the (5) problematic seals that are the source for annoying leaks in 1962-1965 727 pushbutton transmissions. I have been running this kit in a 727 pushbutton automatic car for 3.5 years and 20,000 miles and the driveway is spot-free and the trans is leak-free. This kit may also fit earlier 727s and perhaps the 904 transmission. $30 includes shipping and handling. whuston383_at_gmail.com(replace _at_ with @), or 8one8four3four0eight2six call or text. PM is ok but I don't check often.
Wow. You say you have a Sports Fury? Talk about rare.
#2560391 - 10/07/18 01:47 PM 1965 cable shift transmission [Re: moparts]
RATPATROL Offline
Loc: mi
727 big block pushbutton auto trans, 1 year slip yoke, previously rebuilt at some point and in good working condition when pulled. $600 call if interested. 586 7096113.
Edited by RATPATROL (10/07/18 01:50 PM)
#2562085 - 10/10/18 05:15 PM Re: 1965 cable shift transmission [Re: RATPATROL]
J. Hammer Offline
Loc: Memphis,TN
TCI Breakaway 2400 stall converter PN 141300,fits 904 non lockup. Good for mild street cars,has less than 500 trouble free miles on it. Went to a 9.5" 4000 converter after some engine upgrades. List 389.95,my price is 250.00 plus half shipping costs(ground only). Contact me with any questions.
#2562552 - 10/11/18 04:54 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
727builder Offline
Loc: Tennessee
Selling off part of my inventory of the 1-3/4" Wide kickdown (2nd gear) bands for 904 transmissions. Very hard to find. $100 per band with no core charge. Order more than one? Each additional band is $80 each.
$15 shipping to the lower 48.
Pm me here, Or Call or text for quicker reply.
Carl 423-402-6752
Thanks Moparts!!
#2564506 - 10/15/18 03:39 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
mjtx Offline
Loc: texas
1965 BB 727 push button trans. has a slip yoke rear. Was a pull out of wreck,never opened has been sitting inside for 30 plus years. 350.00 plus shipping.can strap to pallet if needed.call mike 210-415-8925 MJCX@sbcglobal.net
Page 1 of 3 1 2 3 >
25,621 Registered Members
195,462 Topics
2001 Ford Ranger PCM Question
by 70sixpkRT
12/09/18 01:56 PM
chrome shops in north jersey
by yella71
12/09/18 12:09 PM
Neighbors new house foundation question
by 71TA
12/09/18 11:50 AM
AMK alternator bolt kits for 440-6
by 4406bbl
12/09/18 11:50 AM
