Pinion snubber bumper installation #2561662
10/09/18 11:16 PM
10/09/18 11:16 PM
Polson, MT
DoctorDiff Offline OP
Polson, MT
Does anyone know a clean method to install a new pinion snubber bumper?
I can't figure out how to bend those tabs over without distorting the rubber mount at the same time.
Re: Pinion snubber bumper installation [Re: DoctorDiff] #2562500
10/11/18 04:58 PM
10/11/18 04:58 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Factory one or the adjustable aftermarket one? Not sure I have an answer, but a better idea of what it looks like may lead to some ideas.
Re: Pinion snubber bumper installation [Re: Neil] #2562523
10/11/18 06:00 PM
10/11/18 06:00 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
Cass-I had the company that made the first run of the Dana snubbers install a NOS rubber on one of their bases.They said they had to have die/tool made because of the same problem you are having.I'm not sure if they are still doing them.
Re: Pinion snubber bumper installation [Re: DoctorDiff] #2562714
10/12/18 12:35 AM
10/12/18 12:35 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Probably need a tool where both tabs are bent at the same time like the anvil of a stabler while backing up the rubber securely. I run into this crap all the time. Tough to duplicate on a budget what the factory could justify spending thousands on dedicated tooling - my background is industrial automation. Seen a BUNCH of auto factory and automotive supplier machines and tool over 30 years.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
