Why did they stop with springs in lower rad hoses?
#2560354
10/07/18 02:17 PM
10/07/18 02:17 PM
Posts: 15,713 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Were they just deemed unnecessary, or are they just saving money? If my old hose had one I would have transferred it.
I think there's a possibility the hose may have collapsed a couple times in my Power Wagon while in traffic on hot day. Gauge shot up. Everything new including hoses, max cooling rad, milodon thermostat, milodon water pump, block flushed, new freeze plugs, and coolant distilled water mix. I couldn't get out and look at hose in traffic. I guess gauge could be faulty but temps went right back down when traffic started moving again.
Why did they remove springs?
Facts are stubborn things.
Re: Why did they stop with springs in lower rad hoses?
[Re: larrymopar360]
#2560430
10/07/18 06:16 PM
10/07/18 06:16 PM
RapidRobert
Gauge shot up. I guess gauge could be faulty but temps went right back down when traffic started moving again. Electric gauges? I'm thinking just normal temp bump from less air/water flow at idle.
[Re: larrymopar360]
#2560901
10/08/18 02:58 PM
10/08/18 02:58 PM
Posts: 1,231 Chicago, IL
PLUM_72
Chicago, IL
So can one buy a replacement spring to put in a lower hose, if you wanted one?
1972 Dodge Challenger
[Re: PLUM_72]
#2560924
10/08/18 03:26 PM
10/08/18 03:26 PM
Posts: 4,315 St. Louis, Mo
318 Stroker
St. Louis, Mo
So can one buy a replacement spring to put in a lower hose, if you wanted one? I went to the local auto parts stores and bought a universal corrugated hose with a spring in it for 10.00. Pulled it and installed in my hose.
[Re: larrymopar360]
#2560949
10/08/18 04:14 PM
10/08/18 04:14 PM
318 Stroker
St. Louis, Mo
Why did they remove springs? It is my understanding that cooling issues in the conditions you describe is a cooling system issue, and that the high temps on the highway are related to the lower hose collapsing.
[Re: larrymopar360]
#2560986
10/08/18 05:25 PM
10/08/18 05:25 PM
Posts: 4,848 Memphis
HemiRick
Memphis
the 15 psi inside a proper cooling system should easily keep the hose from collapsing.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: larrymopar360]
#2561030
10/08/18 07:10 PM
10/08/18 07:10 PM
PLUM_72
Chicago, IL
(sarcastic statement) Is this something they look for when judging a vehicle at the concours level?
[Re: PLUM_72]
#2561087
10/08/18 09:37 PM
10/08/18 09:37 PM
Posts: 784 Florida
cbusters
(sarcastic statement) Is this something they look for when judging a vehicle at the concours level? Its called the Charmin Test. It is in the Judging Guide, look it up.
[Re: larrymopar360]
#2561092
10/08/18 09:46 PM
10/08/18 09:46 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
if your lower hose is collapsing your problem is not lack of a spring. It is something else.
Why does it collapse and what causes the condition needed? It's not lack of a spring.
[Re: HemiRick]
#2561093
10/08/18 09:46 PM
10/08/18 09:46 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
the 15 psi inside a proper cooling system should easily keep the hose from collapsing. I'm pretty sure that's not how it works There is only 15 psi in the entire system when the temperature is quite high. At 180 degrees there is a few psi on the output side of the water pump (that's what moves the coolant through the radiator, heads, block...) but the inlet side can very well be under suction. A lower hose collapses because it's being sucked in, which by definition means there is negative pressure inside it. Now if there's a restriction in a clogged-up radiator, it's even more likely that the water pump will have vacuum at its inlet (the lower hose)...
