Re: Put thread inserts in new aluminum heads?
[Re: DGS]
#2560794
10/08/18 11:54 AM
10/08/18 11:54 AM
Posts: 2,628 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Forget that idea. Does a Ferrari, Lamborghini, Mercedes, Bugatti, Race Hemi or $100,000 Mountain Motor Pro Stock have heli coils? No.
2011 Drag Pak Challenger
[Re: rickseeman]
#2561121
10/08/18 10:33 PM
10/08/18 10:33 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Forget that idea. Does a Ferrari, Lamborghini, Mercedes, Bugatti, Race Hemi or $100,000 Mountain Motor Pro Stock have heli coils? No. Tell you what, you buy me any one of those things on your list and I promise to never put a helicoil in them. I had to put a bunch of helicoils in a 727 when some jackwagon used the German method (goodentite) to torque the trans pan bolts and stripped a bunch.
[Re: DGS]
#2562073
10/10/18 06:44 PM
10/10/18 06:44 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Stud it where possible. In places where that is not possible and the fastener will be removed frequently it would be a good idea to use an old school Heli-coil.
I ran a quasi-instrumented test (torque to yield and 10,000 lb tension failure) on the various types of thread inserts and the Heli-coil performed as well as or better than the other commonly found styles.
