Re: Need 1973 Duster wiring diagrams please!
[Re: 69bronzeT5]
#256038
03/16/09 08:39 PM
03/16/09 08:39 PM
Posts: 779 Washington
RCuda
If ya snooze..Ya lose!!
Washington
[Re: RCuda]
#256039
03/16/09 08:41 PM
03/16/09 08:41 PM
RCuda
Washington
[Re: IMGTX]
#256046
03/16/09 09:14 PM
03/16/09 09:14 PM
Posts: 1,805 B.C, Canada
69bronzeT5
B.C, Canada
I'm looking for the diagrams because I'm doing starter and alternator wiring.
Feature Editor; Mopar Connection Magazine
'69 Charger- T5 Copper- 383 auto '70 Coronet 500- F8 Green- 318 auto '71 Charger R/T- B5 Blue- 440 auto '71 Charger R/T- GY3 Citron Yella- 440 auto '71 Charger Super Bee- GY3 Citron Yella- U-Code 440 4-spd '79 Power Wagon- Red- 318 auto 4x4 '06 Grand Cherokee SRT8- Black- 6.1L HEMI auto '08 Challenger SRT8- Hemi Orange- 6.1L HEMI auto '12 Ram 3500- True Blue- 6.7L Cummins Auto 4x4 '17 Wrangler Winter Edition- Plum Crazy- 3.6L 6-Speed
[Re: 69bronzeT5]
#256051
03/17/09 12:47 AM
03/17/09 12:47 AM
Posts: 12,229 Looking for a way out of Middl...
IMGTX
Here is a better copy of the Engine Wiring. If you look each wire is numbered. The numbering goes like this. The wire from the battery to the starter relay is A1A-10R A1A is the number to trace through the diagram, 10 is the wire guage and R is the color or Red. Numbered wires like J7-18GY* that end in an asterisk have a White Stripe noted by the * and no second color. Numbers that end in two colors and an asterisk are striped with the second color. For Example J5-18BK/Y* is an 18 guage black wire with a yellow stripe. I will try to ge the under dash wiring scanned tomorrow. These are B body diagrams but they are the same inside the engine compartment and only slightly different under the dash. Open the attachment above and you will see a larger diagram. Hope it helps.
[Re: Wedgeman]
#256055
03/17/09 10:19 AM
03/17/09 10:19 AM
IMGTX
Hey Snoopy !
You would not happen to have on for a 94 5.9l by any chance ?
I have some more but here is an over view of the 5.9. What are you doing with it? I am trying to put a 5.9 in my 70. I will get the others together with the rest of the dash wiring tonight.
[Re: IMGTX]
#256056
03/17/09 02:09 PM
03/17/09 02:09 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
I'm putting it in my 67 Barracuda...it looks like a very easy swap coming from a B350 Van, even the engine mounts look the same ! I will make a trial fit tonight and let you know.... I'm getting the '94 shop manual from Dodge tonight too !!
BUt will the new alt draw too much current for the old electronic set up ?? that I don't know yet
If I knew how to add an image I would.....
Dan
