Page 1 of 3 1 2 3
Why did they stop with springs in lower rad hoses? #2560354
10/07/18 02:17 PM
10/07/18 02:17 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Were they just deemed unnecessary, or are they just saving money? If my old hose had one I would have transferred it.
I think there's a possibility the hose may have collapsed a couple times in my Power Wagon while in traffic on hot day. Gauge shot up. Everything new including hoses, max cooling rad, milodon thermostat, milodon water pump, block flushed, new freeze plugs, and coolant distilled water mix. I couldn't get out and look at hose in traffic. I guess gauge could be faulty but temps went right back down when traffic started moving again.
Why did they remove springs?
Facts are stubborn things.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2560358
10/07/18 02:25 PM
10/07/18 02:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Stronger materials and yes saving a few pennies.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2560366
10/07/18 02:55 PM
10/07/18 02:55 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Pure money savings. Just like when you buy a brake hose they no longer come with new copper washers.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2560367
10/07/18 02:56 PM
10/07/18 02:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I can tell you the only reason they put them there was for initial fill purposes only. It was NOT to keep the hose from collapsing in use.
They probably quit putting them in because they started using a new fill method.
http://automotivemileposts.com/autobrevity/moldedhosecoil.html
http://www.martiauto.com/faqfocus.cfm?qid=20
Don't be the exception.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2560425
10/07/18 05:48 PM
10/07/18 05:48 PM
Courtenay, B.C.
DarrenS Offline
DarrenS  Offline
Courtenay, B.C.
Thanks for that link, Supercuda. That was interesting.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2560430
10/07/18 06:16 PM
10/07/18 06:16 PM
Gauge shot up. I guess gauge could be faulty but temps went right back down when traffic started moving again.
Electric gauges? I'm thinking just normal temp bump from less air/water flow at idle.
Re: Why did they stop with springs in lower rad hoses? [Re: RapidRobert] #2560719
10/08/18 09:52 AM
10/08/18 09:52 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I always transfer my spring when putting in a new hose. I don't care what they say, it IS needed! I helped fix a factory Hemi Dart that was overheating. I stood above his radiator as he revved it up and watched the hose collapse shut! eek
JB Rhinehart, Realist
A-Body's RULE!
Re: Why did they stop with springs in lower rad hoses? [Re: Rhinodart] #2560870
10/08/18 01:42 PM
10/08/18 01:42 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
iagree On my Challenger, I could watch my temp gauge climb on the highway. I put a lower spring in, and no problems since then.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2560901
10/08/18 02:58 PM
10/08/18 02:58 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
So can one buy a replacement spring to put in a lower hose, if you wanted one?
1972 Dodge Challenger
Re: Why did they stop with springs in lower rad hoses? [Re: PLUM_72] #2560906
10/08/18 03:04 PM
10/08/18 03:04 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I ordered from CJ Pony Parts. Lower radiator hose spring stainless steel small block 1965-73. It was $8.99
https://www.cjponyparts.com/catalogsearc...l+block+1965-73
Scott
1969 Super Bee, 383/4 speed
Re: Why did they stop with springs in lower rad hoses? [Re: PLUM_72] #2560924
10/08/18 03:26 PM
10/08/18 03:26 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I went to the local auto parts stores and bought a universal corrugated hose with a spring in it for 10.00. Pulled it and installed in my hose.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2560928
10/08/18 03:32 PM
10/08/18 03:32 PM
florida/ Georgia
Tom Fox Offline
Tom Fox  Offline
florida/ Georgia
large pop-up sprinkler heads have stainless spring. just stretch it to length
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2560949
10/08/18 04:14 PM
10/08/18 04:14 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
It is my understanding that cooling issues in the conditions you describe is a cooling system issue, and that the high temps on the highway are related to the lower hose collapsing.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2560986
10/08/18 05:25 PM
10/08/18 05:25 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
the 15 psi inside a proper cooling system should easily keep the hose from collapsing.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2561030
10/08/18 07:10 PM
10/08/18 07:10 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
(sarcastic statement) Is this something they look for when judging a vehicle at the concours level?
Re: Why did they stop with springs in lower rad hoses? [Re: PLUM_72] #2561087
10/08/18 09:37 PM
10/08/18 09:37 PM
cbusters Offline
cbusters  Offline
Its called the Charmin Test. It is in the Judging Guide, look it up.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2561092
10/08/18 09:46 PM
10/08/18 09:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
if your lower hose is collapsing your problem is not lack of a spring. It is something else.
Why does it collapse and what causes the condition needed? It's not lack of a spring.
Re: Why did they stop with springs in lower rad hoses? [Re: HemiRick] #2561093
10/08/18 09:46 PM
10/08/18 09:46 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I'm pretty sure that's not how it works wink There is only 15 psi in the entire system when the temperature is quite high. At 180 degrees there is a few psi on the output side of the water pump (that's what moves the coolant through the radiator, heads, block...) but the inlet side can very well be under suction. A lower hose collapses because it's being sucked in, which by definition means there is negative pressure inside it. work
Now if there's a restriction in a clogged-up radiator, it's even more likely that the water pump will have vacuum at its inlet (the lower hose)...
Re: Why did they stop with springs in lower rad hoses? [Re: DrCharles] #2561118
10/08/18 10:26 PM
10/08/18 10:26 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
iagree Very well worded... up
A-Body's RULE!
Re: Why did they stop with springs in lower rad hoses? [Re: Rhinodart] #2561210
10/09/18 01:05 AM
10/09/18 01:05 AM
If the no spring is causing it to overheat at idle/low speed I would think it would be worse at high speed on the highway (with higher suction on the hose if that is linear) & he says it is OK then.
Page 1 of 3 1 2 3
