Re: Not charging
[Re: Scott Carl]
#2559647
10/05/18 09:23 PM
10/05/18 09:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
None of us are Karnak
You know when you go to the parts store and he asks you year/make/model/engine?
You do understand there is a reason for that right?
if you want help you have to be more specific on your combo
Re: Not charging
[Re: Scott Carl]
#2559735
10/06/18 01:56 AM
10/06/18 01:56 AM
RapidRobert
Any ideas. FYI, I'm running a hot wire directly from the battery to the alternator. So I know it's getting power from the Alt... Hello Carl, I'm always glad to help my Omaha brother! You mean you have a big jumper from the alt threaded "batt" stud to the batt positive terminal? that does not "energize" the alt, it just bypasses the ammeter/bulkhead & their associated wiring path/connectors for the alt circular route "output" path which are prone to issues (but not a dealbreaker) just clean EVERY terminal including ground paths, a seperate issue. If this is the '70 earlier system with the "box" reg/single field terminal alt, turn the key on & see if the "ign" terminal on the reg is hot & the fld" terminal on the other side of it is hot & the green wire from the reg "fld" terminal is hot at the alt field terminal. If this is the later "flat" reg system with the triangle connector & a 2 field terminal alt, turn the key on & see if the blue wire terminal in the triangle connector is hot & with it plugged into the reg triangle, stick a pin into the green wire terminal & see if it is hot & at the alt see if the green wire field terminal is hot. confirm the reg is grounded, usually removing the mounting bolts & screwing them back will take care of that. that'll oughta tell us something.
Re: Not charging
[Re: Supercuda]
#2560390
10/07/18 03:45 PM
10/07/18 03:45 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
My bad. 74 Challenger 318/904 Stock wiring system
Re: Not charging
[Re: IMGTX]
#2560546
10/07/18 10:11 PM
10/07/18 10:11 PM
Scott Carl
Omaha, Nebraska
OK
If you have an Ohm meter. Disconnect the battery to protect the ohm meter and disconnect the field wires (small wires) to the alternator and the Voltage Regulator. Check for 0 resistance from the blue Voltage regulator wire to the Blue wire on the alternator. Also check for 0 resistance from green to green. Then check to be sure the blue and green are not shorted to each other.
If you have an open wire check the mass connector on the engine wiring harness behind the passenger side valve cover. Commonly burned out on the 73/74 E-bodies. If that is OK then peel the wiring along the passenger side valve cover from the alternator to the bulk connector and look for burnt wires. Very common on all Mopars from the 60's through 80's.
When I first started getting this car running, I did discover some burned blue wires on the run along the pass side valve cover. I had to replace some wire then. May have to open it up again and check for more burnt wires again...
Re: Not charging
[Re: Scott Carl]
#2563226
10/13/18 02:23 AM
10/13/18 02:23 AM
RapidRobert
all good there. turn the key "on" & the blue wire there at the alt & at the "top" blue wire terminal in the triangle reg connector (with it facing up like a pyramid), some are sideways, but the blue & green are always the same, should also be hot. confirm the yellow wire has continuity between the other alt field terminal & the "side" terminal at the reg (likely it is OK) & confirm the reg is grounded (unscrew/screw in the mounting bolts will do it) then all that is left is bad reg.
Re: Not charging
[Re: Scott Carl]
#2584980
11/30/18 12:38 AM
11/30/18 12:38 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Without an ammeter in the charging circuit, its only a guess to what the charging current is. However you'll damage the battery for sure if its seeing 16 Volts. That's a very specific statement. If the voltage across the battery is 16 volts. If the voltage across the battery is 14.5 Volts, then it will be OK even if the voltage at the alternator output is 16 Volts.
Even so, you still need to find out why there's a voltage difference. Often its poor connections or wires between the alternator output and the voltage regulator's 'sensing' connection. If there are voltage drops between the alternator out and the regulator sense, the regulator is operating correctly but being given incorrect info. The regulator keeps upping the current allowed through the field until it sees 14.2 - 14.9 Volts.
Schematicly your charging system looks something like this. Or did before it was altered. Actual colors and connection points you'll have to get from a '74 factory service manual. To find the culprit(s) check the voltage at each accessible point between the alternator output stud and the regulator. Alternatively (pun intended), instead of measuring voltages to ground, measure voltage drops in the circuit itself. Also check there are no voltage differences between the ground system from body, engine, battery and alternator.
Re: Not charging
[Re: Mattax]
#2585010
11/30/18 02:08 AM
11/30/18 02:08 AM
RapidRobert
Confirm the battery is charged up (slo charge it overnight if need be). What Mattax said: 16V is sky high & will fry the system. at a fast idle (with a good meter) see what you have at the batt posts & work outward from there. If 16V stop the eng & do some checking as much as you can WO it running to see if you can spot the problem (something is dead shorted/full fielded/wired wrong or bad reg). keep run time to a BARE minimum. unplug the reg & see what it drops to. EDIT & keep all lights/accessories OFF as 16V will fry em.
Re: Not charging
[Re: Scott Carl]
#2585220
11/30/18 03:33 PM
11/30/18 03:33 PM
Mattax
Phila. Pa.
Its very hard to track a voltage drop without having equipement running. Current has to be flowing for there to be a voltage drop.
Before shutting down, measure the voltage at the alternator output, and regulator sensing wire. Probably the closest two locations for that will be the ignition run wire (blue) at the ballast resistor and the field connection on the alternator.
With the engine off, you'll have to set up tests using the battery to supply power through a couple different circuits. Not that difficult.
IMGTX's post is very good. Read it again if needed.
Below is normal paths of current flow when a battery is fully charged and the engine is running.
Re: Not charging
[Re: Mattax]
#2585309
11/30/18 07:06 PM
11/30/18 07:06 PM
RapidRobert
Agreed, if it ain't flowin it ain't droppin but I would try & do as much as you can ahead of time (eng off). Ohm the alt male field terminals to ground (shouldn't be)/ohm green wire to ground (should be none)/confirm the field circuit wiring is correct (I'm assuming nothing was rewired- it just started overcharging). My gut is telling me that it is the reg (even tho it is new) IF the alt field terminals are isolated. A good precaution, pull a batt cable before switching the meter to ohms.
Re: Not charging
[Re: Scott Carl]
#2656309
05/17/19 04:27 PM
05/17/19 04:27 PM
Scott Carl
Omaha, Nebraska
Sorry for the lag in responding. Been a long winter. So, I re checked all the connections, and eliminated issues there. Did have a questionable connection on the output post. but discovered I had a faulty alternator. Went from over charging to nothing. New alt and runs great! Need a new battery as it won't hold a charge for more than a few days, but will start and run nice (electrically, still have a littel carb issue) if drive it every other day or so Scott
