What is this bolt for? #2559221
10/05/18 02:17 AM
10/05/18 02:17 AM
West Plains, MO
DrCharles Offline OP
West Plains, MO
There's a bolt on the top of the hood latch support ('72 Dart). Nothing's attached to it. What is it for?
The only thing I can think of is some kind of bushing to protect the paint from the hood tongue as it passes through?
thanks.
Re: What is this bolt for? [Re: DrCharles] #2559243
10/05/18 03:12 AM
10/05/18 03:12 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
How about the brace that goes from there to the bottom of the core support? You see it is there to support the hood latch.
Re: What is this bolt for? [Re: DrCharles] #2559339
10/05/18 12:05 PM
10/05/18 12:05 PM
West Plains, MO
West Plains, MO
But the nut is permanently attached (spot-welded) to the sheet metal, and the bolt goes in from the top so whatever it holds also has to be on top. So I can't see how it would go to the bottom of the core support. confused
Anyone got a picture of this area?
Re: What is this bolt for? [Re: DrCharles] #2559358
10/05/18 12:44 PM
10/05/18 12:44 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Goes to the vertical brace that mounts under the header panel.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: What is this bolt for? [Re: DrCharles] #2559366
10/05/18 12:55 PM
10/05/18 12:55 PM
West Plains, MO
West Plains, MO
Thanks. A picture is worth 1000 words wink I guess the nut is actually affixed to the brace, not the horizontal support whistling
I'll go take another look at it.
Meanwhile, IS there any "liner" for the hood tongue opening so the paint doesn't get scuffed every time the hood is closed? work
Re: What is this bolt for? [Re: DrCharles] #2559369
10/05/18 01:07 PM
10/05/18 01:07 PM
moparmarks Offline
moparmarks  Offline
YES
I pull on the safety release when shutting the hood so the ears don't scratch the paint. Otherwise might try some clear packaging tape.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: What is this bolt for? [Re: moparmarks] #2559791
10/06/18 11:12 AM
10/06/18 11:12 AM
moparx Offline
moparx  Offline
for what it's worth, my one buddy uses a 35mm film canister cap on the big hood spring to keep the under side of the hood paint from being destroyed.
beer
Re: What is this bolt for? [Re: DrCharles] #2560058
10/06/18 08:23 PM
10/06/18 08:23 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
iagree good advice
Re: What is this bolt for? [Re: moparx] #2560126
10/06/18 10:39 PM
10/06/18 10:39 PM
8
86 Shelby GLHS
86 Shelby GLHS
beer
I put a condom on mine.
Re: What is this bolt for? [Re: DrCharles] #2560175
10/06/18 11:57 PM
10/06/18 11:57 PM
cbusters Offline
cbusters  Offline
There is a Ford minivan that is supposed to have a factory cap on the spring and it will fit the Mopars.
Re: What is this bolt for? [Re: ] #2560195
10/07/18 12:45 AM
10/07/18 12:45 AM
West Plains, MO
West Plains, MO
beer
Thanks for the reminder, I completely forgot about the top of the spring also scratching up the paint. A latex condom is just a few thousandths thick - how often do you have to change it? whistling
I may try threading a piece of shrink tubing over the first turn, and hitting it with the heat gun so it'll stay in place. If I start buying prophylactics I will get a lot of questions and "looks" at home.
apimp
Re: What is this bolt for? [Re: DrCharles] #2560832
10/08/18 12:43 PM
10/08/18 12:43 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
A short piece of vacuum hose on the end of the spring will protect the paint and it looks better then a film cap IMO.
Re: What is this bolt for? [Re: DrCharles] #2561249
10/09/18 02:47 AM
10/09/18 02:47 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
X2, what I use...
Joe
Re: What is this bolt for? [Re: burdar] #2561332
10/09/18 11:33 AM
10/09/18 11:33 AM
moparx Offline
moparx  Offline
that is a great tip ! i never gave that a thought, but i agree, it would look MUCH better than a film cap. Thank You !
beer
Re: What is this bolt for? [Re: DrCharles] #2561357
10/09/18 12:28 PM
10/09/18 12:28 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Use a piece of "clear" tubing to slide over it. Most people won't even notice it is there. Buy it at your local hardware store.
