Re: 3.6 pentastar V6 questions
[Re: NEVjr]
#2559557
10/05/18 05:46 PM
10/05/18 05:46 PM
Posts: 2,254 IL
furious70
IL
The TF8 is huge. I measured the one in my 2012 Charger, 30" from bell to rear mount and it's 9" tall at the mount. It doesn't really taper into the tail.
I don't know if the cams work like the hemi or not, but those guys physically block the gear to lock it in. There's a thread near the top of the G3 forum right now.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: NEVjr]
#2559685
10/05/18 10:55 PM
10/05/18 10:55 PM
Posts: 141 Missouri
randavis
Missouri
I think that the oil pressure is switched from high to low when the engine temp reaches a certain point. I have a 2013 Ram with that engine. I can watch the oil pressure and temperature on my dash screen.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: randavis]
#2559695
10/05/18 11:15 PM
10/05/18 11:15 PM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
I've wondered how the 3.6 would do in an early A-body Valiant. So a 3.6 has a sb bellhousing pattern? My first car was a '65 and if I find another one, that would be something to consider. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: NEVjr]
#2559973
10/06/18 05:25 PM
10/06/18 05:25 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I think your better off running a trans intended for that engine either from a 2wd ram or a charger/challenger/300...
[Re: NEVjr]
#2559976
10/06/18 05:27 PM
10/06/18 05:27 PM
HotRodDave
Kalispell Mt.
I guess I should explain my reasoning a tad, there are more gear ratios, a converter is already matched to it so no need to play with converters trying to find one that works just right plus the 3.6 is drive by wire and the 904 needs a throttle cable unless you go full manual.
[Re: NEVjr]
#2560140
10/06/18 10:49 PM
10/06/18 10:49 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Just put a stick behind it and not worry about kickdonws or trans controllers.
[Re: NEVjr]
#2560221
10/07/18 02:21 AM
10/07/18 02:21 AM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
Going to follow this myself. I'd love to put a Pentastar 3.6 in my 97 Dakota
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: Supercuda]
#2560357
10/07/18 02:23 PM
10/07/18 02:23 PM
Posts: 81 Alberta
NEVjr
Alberta
Just put a stick behind it and not worry about kickdonws or trans controllers. the 2 questions everyone asks: what year is it? does it have the pushbutton shifter? its gotta have the pushbutton Anyone know what RPM the variable runner length valve changes?
[Re: NEVjr]
#2560472
10/07/18 07:29 PM
10/07/18 07:29 PM
Posts: 350 central IL
myduster360
central IL
1972 Swinger 3.6L Pentastar Diablo CMR tuner
[Re: NEVjr]
#2560483
10/07/18 07:48 PM
10/07/18 07:48 PM
myduster360
central IL
working on a pentastar v6 swap into my valiant, got a few questions about its internal workings
-If the cam phasor spool valve isnt pulsed after start up, the cams run in the lock pin position, or will they drift? -How does the oil pump switch from high to low? RPM? engine load? -do these use throttle delays or limits to prevent detonation?
any other info you can give me would be much appreciated Cams run to the lock pin after start up. Not sure how much can be done about changing it at idle. I haven't fabbed up any "manifolds" for my 3.6l so its loud as hell for the 1st 30s and then the cam timing makes an obvious change and the decibel levels slowly drop by 2/3. I haven't seen any setting the PCM as far as Oil pressure control in HpTuners or Diablo, so unsure about the when but I'd guess RPM and load. Cam timing is used for psuedo-EGR like affect to combat detonation. I don't see any Throttle modifiers associated with Knock. I'm not aware of any Pentastar with a variable intake. I know my Jeep/Ram intake and my Caravan intake do not. im not sure of the 2016 and newer PSU engines NO the 3.6L doesn't share the bellhousing with much anything but maybe a 3.5L
[Re: myduster360]
#2560522
10/07/18 09:21 PM
10/07/18 09:21 PM
I_bleed_MOPAR
Buford, GA
Sweet! Do you have a build page somewhere? If not, I have a ton of questions for you. Tim
[Re: I_bleed_MOPAR]
#2560613
10/08/18 12:06 AM
10/08/18 12:06 AM
Posts: 3,378 KY USA
mopargem
KY USA
Can’t help you any with installation but it’s a great engine. I smoke people all the time in our 2015 Town & Country hehe! Surprising power for this big old heavy van.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: myduster360]
#2560681
10/08/18 03:20 AM
10/08/18 03:20 AM
Posts: 81 Alberta
NEVjr
Alberta
any other info you can give me would be much appreciated Cams run to the lock pin after start up. Not sure how much can be done about changing it at idle. I haven't fabbed up any "manifolds" for my 3.6l so its loud as hell for the 1st 30s and then the cam timing makes an obvious change and the decibel levels slowly drop by 2/3. I haven't seen any setting the PCM as far as Oil pressure control in HpTuners or Diablo, so unsure about the when but I'd guess RPM and load. Cam timing is used for psuedo-EGR like affect to combat detonation. I don't see any Throttle modifiers associated with Knock. I'm not aware of any Pentastar with a variable intake. I know my Jeep/Ram intake and my Caravan intake do not. im not sure of the 2016 and newer PSU engines NO the 3.6L doesn't share the bellhousing with much anything but maybe a 3.5L atleast as of 2018 they all have an intake runner length valve what are you using for an ECU? it sounds like you are able to read from it? fly by wire throttle? what donor vehicle? what all came from the donor vehicle? where is the O2 sensor? does your ECU require the after cat sensor? any other trap, pitfalls, or dragons to be aware of?
[Re: NEVjr]
#2560855
10/08/18 01:15 PM
10/08/18 01:15 PM
myduster360
central IL
[quote=myduster360][quote=NEVjr] what are you using for an ECU? it sounds like you are able to read from it? fly by wire throttle? what donor vehicle? what all came from the donor vehicle? where is the O2 sensor? does your ECU require the after cat sensor? any other trap, pitfalls, or dragons to be aware of?
2013 Manual trans Wrangler PCM. I use HP Tuners and DiabloSport CMR for Custom tuning. yes I use the stock pedal sensor. I kept wiring as stock as I could. No cats in a 72 Swinger(lol), so Rear O2 sensors are OFF in the tune along with A LOT of other crap(ie:evap). My "Exhaust manifolds" aren't done yet, so I didn't have upstream O2 sensors installed during that video. 1st fire was last Friday night. Biggest issue so far has been interference with the steering gear and column with the A/C compressor(i had to delete it) and routing exhaust. The 3.6l is WIDE! As wide as a 440 valve cover to valve cover! Tons of info in my Build thread. https://www.forabodiesonly.com/mopar/threads/72-dart-swinger-3-6l-pentastar-t5.361683/
[Re: NEVjr]
#2560889
10/08/18 02:40 PM
10/08/18 02:40 PM
myduster360
central IL
[quote=NEVjr]I'm not aware of any Pentastar with a variable intake. I know my Jeep/Ram intake and my Caravan intake do not. im not sure of the 2016 and newer PSU engines atleast as of 2018 they all have an intake runner length valve 2016 and newer PSU 3.6L has a lot cool upgrades like Cooled EGR and Variable Valve LIFT, but nothing about a variable intake. This is the only mention of the intake manifold in Wards AutoWorld thorough write up "The intake manifold is all-new, with longer runners to boost torque."2016 and newer 3.6L may not be a sturdy as the 1st gen if you plan on a turbo or supercharger. The article mentions that in an effort to reduce overal weight, FCA " reduced the size of the main bearings and crankshaft pins and using thin-wall castings"
[Re: NEVjr]
#2562292
10/11/18 03:00 AM
10/11/18 03:00 AM
I_bleed_MOPAR
Buford, GA
My thoughts exactly. Power it makes and the weight savings make it ideal in my book for a cruiser. Although I may have to rethink using an early A with the clearance problems he is having. I will definitely be following his thread. Tim
[Re: NEVjr]
#2566174
10/18/18 10:09 PM
10/18/18 10:09 PM
Posts: 141 Missouri
randavis
Missouri
I checked my 2013 Ram today and the oil pressure stays high (~80 psi) until the water temp gets to 192*.
