Re: rear door on 08 ram wont open
[Re: BigTerry]
#2557944
10/02/18 09:12 PM
10/02/18 09:12 PM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
Dumb question time.... did you check to see if the child lock had been flipped on? Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: BigTerry]
#2561692
10/09/18 11:46 PM
10/09/18 11:46 PM
Posts: 1,730 elyria, ohio
72gtx4speed
elyria, ohio
The bottom latch has a tendency to rust up on those doors. Remove the door panel and start spraying a penetrant. Let it soak.
Good luck Clem
when i grow up i want to be just like sunroofgtx, god please don't let me grow up.
[Re: 72gtx4speed]
#2562044
10/10/18 05:29 PM
10/10/18 05:29 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Good luck Clem If it was a 98-02 I would agree, but an 08 has the latch like the front doors.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2562550
10/11/18 06:52 PM
10/11/18 06:52 PM
72gtx4speed
elyria, ohio
I just reread the post and realized i misread it the first time. The bottom latch has a tendency to rust up on those doors. Remove the door panel and start spraying a penetrant. Let it soak.
[Re: Silver70]
#2564016
10/14/18 07:32 PM
10/14/18 07:32 PM
I_bleed_MOPAR
Buford, GA
You may need to R&R the latch assy. to inspect it and/or clean & lube it (or go ahead and replace it). If the inside handle linkage is still attached to latch, then it may be a problem with the child lock part of the latch. Taking the latch assy. out would make it easier to see and work on. Tim
