Page 2 of 6 < 1 2 3 4 5 6 >
#2559874 - 10/06/18 11:42 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
furious70 Offline
Loc: IL
Two early 1972 440 blocks and caps, no VIN's or upper pad stampings. I measured them both at .006-.010 wear from standard but I am no machinist. $500obo each
in eastern Iowa but can get to Chicago
Edited by furious70 (10/06/18 11:42 AM)
#2559878 - 10/06/18 11:44 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
furious70 Offline
Loc: IL
MP distributor 383/400 elec 3690431 $50
375518 1974 440HP distributor $75
3656344 1972 440 distributor $50
2875715 prestolite 69 383 dual point distributor $150
aluminum dual point 383 distributor (no tag) $50
#2559939 - 10/06/18 02:53 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: furious70]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
YOUR BUYING 5 NORS MADE IN THE USA NIEHOFF AL-43 HEAVY DUTY DUAL POINT IGNITION ROTORS ,WILL FIT 361-383-413-426W-426H-440+6 DODGE,PLYMOUTH,CHRYSLER
CAST IRON FACTORY DUAL POINT DISTRIBUTORS&DC,MP MECHANICAL ADVANCE RACE DISTRIBUTORS
$50 MAILED
cowgerwilliam035@gmail.com
paypal or money order
#2560378 - 10/07/18 01:07 PM 440 pistons rods crank [Re: moparts]
RATPATROL Offline
Loc: mi
440 +030 Ross pistons (99539) 990 pin 6.76 eagle h-beam rods, oem .010 under steel crankshaft. Very little run time on this rotating assembly all balanced and ready to go . $1200. Call if interested. 586 7096113
Edited by RATPATROL (10/07/18 01:20 PM)
#2560399 - 10/07/18 02:16 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
lancer493 Offline
77 440 truck block,thick main web. Bored and honed to 4.350".BCR aluminum main caps,girdle,and ARP studs installed,line bored and honed.Hot tanked and magnafluxed.$1400 worth of machine work all performed by Nelson Competition in Pinellas Park ,Fl.Never used or assembled. My loss,your gain.You finish.$1950.00 Prefer local pick up. Tampa Bay Fl.area. pm me here for more info.I have receipt for machine work. thanks, Bill
#2562418 - 10/11/18 11:06 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
KBW440 DUSTER Offline
Loc: norman oklahoma
I have a 1966 440 block. Text me at 405-830-8593 for pictures and info. Norman Ok. $500.00 or obo
Edited by KBW440 DUSTER (10/11/18 11:08 AM)
#2562431 - 10/11/18 11:34 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
Triggerfish Offline
Loc: Blairsden, CA
SOLD.. thanks Moparts! New Brawler carb 750 Street Series, mechanical secondaries, electric choke. Was on Summit's display engines, never fired or gas run thru. Just bought from Summits demo sale, but I'm going with an Eddy 750 my brother gave me instead. The Brawler's retail price is right around $400, so $200 plus shipping is what I'm asking & that's a great price.
Edited by Triggerfish (10/12/18 10:27 AM)
#2563486 - 10/13/18 04:07 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
SOLD - 120 amp Denso conversion kit complete with reconditioned Denso alternator new in the box. The bracket kit is used but is complete. Fits B or RB engine. $100 for complete kit with alternator plus shipping. Alternator is heavy so shipping will be $25 or $30 depending on location. PayPal preferred. PM me on the board.
Edited by AndyF (10/14/18 11:45 AM)
#2563695 - 10/13/18 11:17 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: AndyF]
'72CudaRacer Offline
Loc: Mooresburg, Tn
Spare rocker arms *NOT A COMPLETE SET*
Mopar Performance, big block, 1.5 ratio, standard offset. $130 for all, shipped (lower 48 only). PM me on here.
NEW- 1 left & 1 right
USED- 3 left & 6 right
Edited by '72CudaRacer (10/13/18 11:19 PM)
#2563702 - 10/13/18 11:27 PM Push rods [Re: '72CudaRacer]
Loc: Mooresburg, Tn
USED-Push rods, 3/8" diameter, .083 wall, 5/16" cup, 3/8" ball, effective length 9.350". No damage, changed combo, too long. $150 shipped (lower 48 only) PM ne on here.
Edited by '72CudaRacer (10/13/18 11:41 PM)
#2563706 - 10/13/18 11:33 PM Big block valve covers [Re: '72CudaRacer]
Loc: Mooresburg, Tn
Fabricated alum valve covers w/ bolts & one breather (kit), new in box. Mopar Performance #P5155526. $275 shipped (lower 48 only) PM me on here.
#2563900 - 10/14/18 01:34 PM Water Pump Pullies Including One for 426 Wedge! [Re: '72CudaRacer]
moparjohn Offline
Loc: N.W. INDIANA
Recently I finished bead blasting and priming my extra water pump pullies. I have now started to look up the ones with part numbers. I have found just one stamped 1821452 and it is for 383 and 426 wedge engines. It is 6 7/8" in diameter and 2 11/16" deep. The price is $40.00 plus shipping. If you interested contact me at: moparjohn@frontier.com
with your zip. If you are looking for an original water pump pulley contact me with the outer diameter and how deep you need as I have many to choose from!
Thanks!
#2563963 - 10/14/18 03:31 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
mike337 Offline
Loc: Cannelton, IN
Edelbrock Performer 750 CFM Carb. 1407/0392 stamping. Just removed from a running engine, $150
Thanx for the ad Moparts!
moparzone4@aol.com
Edited by mike337 (10/14/18 06:43 PM)
#2564367 - 10/15/18 10:59 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
LemonTwiist Offline
Loc: Mechanicsburg, PA
FOR SALE: Used metering block #6512 #4780. It still has the power valve, jets, and needle adjusting screws. The part numbers have been sanded off, but can still be seen in the casting. PRICE $35.00 Plus $6.00 postage
Edited by LemonTwiist (10/15/18 11:03 AM)
#2564374 - 10/15/18 11:17 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
LemonTwiist Offline
SOLD Used Big block 906 head dated April 22, 1970. It is ground 0.10 under. One exhaust manifold stud is broken off It has been cleaned, magna fluxed and has ne cracks. Price $35.00 Plus Postage
Edited by LemonTwiist (11/21/18 08:24 AM)
#2564459 - 10/15/18 02:07 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: LemonTwiist]
Joesixpack Offline
nors Made in the USA hd copper insert dual point distributor cap&made in the USA rotor. will fit all 361-383-413-426w-426h-440+6 cast iron dual points&DC/MP mechanical advance dual point&electronic distributors.
featuring carbon brush, tall coil wire tower,ribbed inside for strength and rigidity. $35 for the pair.
#2564504 - 10/15/18 03:31 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
mjtx Offline
Loc: texas
BIG BLOCK MOPAR ENGINE PARTS. 1-set 6-Pac Rods 2951908 ARP polished and shot peened $275.00. 5-6-Pac Rods $20.00 each. 1 set stock 440 LY Rods 1851535 $80.00. 1 440 LY Rod $15.00. 1-Set 440 Rods #1851535 ARP Full floating pins $200.00. 3 Sets of 400 Rods stock $65.00 for each set. 440 Main caps set of 5 $50.00 or $15.00 each. Set 400 stock push rods $20.00.Set 440 stock push rods $25.00. Good used stock rocker arms $65.00 a set. Have a lot of other small big block engine parts. Can ship USPS for about $14.00 for 70 lbs. Pay Pal or USPS money order. Ship within 2 days.Call Mike at 210-415-8925 or email at mjcx@sbcglobal.net with questions.
#2564666 - 10/15/18 10:03 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
CoDart Offline
Loc: Fort Collins, Colorado
All ads require a price.
Edited by tboomer (10/16/18 06:19 AM)
Edit Reason: no price
#2565351 - 10/17/18 11:55 AM 440 roller rockers-sold. [Re: chrisnben]
migsBIG Offline
Loc: San Jose,CA
Sold.Nearly new Comp Cams Big Block 1.5 ratio Roller Rocker Assemblies. Will work on iron and most aluminum production style heads. Missing box, but near perfect condition as were swapped early on when heads were swapped for more performance. cost $670, $450 shipped 48 states.
pm here for reply.
Sold
Edited by migsBIG (11/01/18 04:59 PM)
#2565525 - 10/17/18 05:18 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
camastomcat Online   content
Loc: Salt Lake City
07 vintage World Aluminum Block 4.510 bore, 55mm cam tunnel, all ARP hardware, pushrod restricted oiling .937 lifter bores, small window but professionally repaired. All this block has had B1, B1/MC, and Predator heads and handles more than 1100 HP. $5800
Winberg 4.625 stroke center counterweight, double keyway crankshaft balanced for 7.100 Oliver Billet steel rods, just back from Mile High Crankshaft $1300 2.200
ATI Balancer for crankshaft $300
Scat 1997 vintage 4340 Crankshaft needs light repair with aluminum Rods $750
Fully Ported Predator Heads with all rocker arms, 7/16 double taper pushrods, titanium valves, PSI springs, billet fab valve covers, cast custom intake with modifications ready to go $8000
Billet Fab Oil Pan with balls and heater provision $450
DaVinci 1050 dominator $750
Jessel Belt Drive $1000
55GPH Meziere Water Pump $400
Crower bushing offset lifers $900
Offset distributor $400
Custom 55 mm billet roller camshaft for above application $650
Or all of the above plus pare push rods, rockers, gaskets, and all information it takes to build one of these engines, all you would need is rods, pistons and assembly $16,000. This combo made north of 1100 HP and 830 FP. The parts mentioned here come to over $21,000.
I am selling either this combo or complete 604 Predator with cast intake and single carburetor, billet fab valve covers, 55mm cam, Steel World Hemi block combo, bigger 2.450, 1.860, titanium valves, center counterweight billet Winberg crankshaft, Oliver Steel rods, Titan oil pump with above oil pan, Jessel belt drive, custom pistons, and some spares for $18,500 1050 Davinci carb to pan.
I am only selling one of these to complete my latest project. I will keep the one that doesn't sell.
Call Tom 801 949 7791
25,697 Registered Members
196,732 Topics
Thermostats designs that “fail open” experiences?
by 360view
01/19/19 09:01 AM
Anyone from Livingston N. J. ?
by blewbyu
01/19/19 08:31 AM
Are cassettes making a comeback?
by DUFFMAN
01/18/19 10:34 PM
Indoor (home) emergency heating, kerosene, propane, other??
by A12
01/18/19 10:31 PM
