Page 1 of 6 1 2 3 4 5 6 >
#2557548 - 10/02/18 09:31 AM For Sale - Big Block Engine - 4th Quarter
moparts Offline
#2557584 - 10/02/18 10:09 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
Goat330 Offline
Loc: Randolph, Ohio--N.E. Ohio
Indy(wedge) cross-ram(NIB),never used it on my project,and (NIB) 750 Edelbrock Performer carb(just one,not 2)+ strip kit for carb. The manifold has the offset mounting not the inline mounts.Will sell all of the above for $1250+ shipping.I would also consider trading for a factory cross ram intake(wedge)don't bug me trying to unload your overpriced intakes for hemi,Bill at wmemore@aol.com or PM. Thank you for free ads Moparts
Here's a link to that photo.
http://s846.photobucket.com/user/Bigemo63/media/102_0367.jpg.html
Edited by Goat330 (10/02/18 12:07 PM)
#2557606 - 10/02/18 10:30 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
modelmakerinc Offline
Loc: west palm beach, florida
440Source distributor for low block, 383/400
Looks almost new was on an engine that is going to upgrade to MSD.
Distributor only $70 obo, shipped to the lower48.
Pm here, text 561.906.0480 email modelmakerinc@att.net
Edited by modelmakerinc (10/02/18 10:33 AM)
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
#2557626 - 10/02/18 11:16 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used chrome thermostat housing. $5
Used Crane cam #278-2. Cam only, no lifters. $75
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner hose. $20
Cal Custom 14" aluminum air cleaner with filter. $100
1970 Single nipple oil breather with hose. $35
New 12" oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
NOS Direct Connection big block double roller timing chain #P4120264. $75
Cal Custom 9" finned air cleaner top and base. No filter. $75
Mr. Gasket 1" thick carb spacer. $15
137 Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
NOS STR-15 383-400 crossram intake manifold with linkage. $2750
1972 400 parts. Oil pump $5, various AC brackets $50 for the lot, spark plug shields $10 pair, exhaust manifold heat stove for non-hp manifolds (needs a little straightening) $15. $50 for everything.
Carb. throttle linkage pin. $10
Used black Mopar Performance aluminum valve covers. $90
Big block flywheel part #2843214 143 tooth. $50
Pair of big block exhaust manifolds. Part numbers 3830800 & 3830820. $100
Pair of big block exhaust manifolds. Part numbers 2532626 & 2532464. $80
Pair of big block heads. Part number 2406516. $100
Alternator date coded 1965. $60
1969 B-body 4 bbl. air cleaner top. $200
1967 440 HP intake manifold #2806178. Media blasted and primed. $100
Prices do not include shipping. gt340 @ yahoo.com
Edited by 6PAX (11/11/18 09:50 PM)
#2558143 - 10/03/18 08:38 AM Re: QFT/Proform-type "950" 1.45" v 4150 Carb [Re: moparts]
johnnyd Offline
Loc: Boston, MA
roller rocker arms for the Brodix B1/BS head. The rockers are the original rockers that came with my B1BS heads. One rocker has minor damage from a push rod cup. I spoke with Scott at Koffel's Place about the damage and he said it was fine to run. $400
More pics here: https://boston.craigslist.org/sob/pts/d/big-block-mopar-mopar-roller/6720476197.html
Edited by johnnyd (10/12/18 11:39 AM)
#2558144 - 10/03/18 08:39 AM 440 main caps [Re: moparts]
johnnyd Offline
Loc: Boston, MA
440 main caps from my cracked block ***SOLD!*** thanks Moparts!
Edited by johnnyd (10/16/18 09:35 AM)
#2558145 - 10/03/18 08:43 AM Mopar 440 bottom end plus more eagle, crane, indy [Re: moparts]
johnnyd Offline
Loc: Boston, MA
My stupidity is your gain. I left a little water in my motor last winter and it was enough to crack my block. I'm thus selling the internals plus a bit more. I have a forged crank, eagle h-beam rods, 13.5:1 BRC .030 pistons all balanced. I'm including the gear drove, Crane .543/.561 roller cam, and Crane Roller lifters. Also include Indy 440-2 intake, Indy valley plate, and pushrods that work on a 440-1 head. Just machine a block, use your heads, install new bearings (rings if you want) and you're good to go. ~50 runs on this bottom end. $2500
pics https://boston.craigslist.org/sob/pts/d/mopar-440-bottom-end-plus/6720476086.html
Edited by johnnyd (10/12/18 11:40 AM)
#2558243 - 10/03/18 12:02 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
luckydave Offline
FACTORY BIG BLOCK ROCKER ARM SETS 4 OF THEM
Great condition
Four sets ---of big block factory hydraulic rocker arms with all spacers and enough hold downs for the lot-- The repo units are China junk and are too narrow and Chatter like crazy--Don't be fooled by them-- use stockers
$50 plus whatever UPS is to you
emails only please dusterdave173@gmail.com
Description: 2
Edited by crabman173 (11/17/18 09:43 AM)
#2558244 - 10/03/18 12:03 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
luckydave Offline
REAR MAIN SEAL HOLDERS
TWO USED REAR SEAL HOLDERS WITH BOLTS
$29 shipped free dusterdave173@gmail please email no PM's Thanks
Description: 4
#2558245 - 10/03/18 12:05 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
luckydave Offline
NICE set 383-400 main caps off 400 block $35 shipped free
dusterdave173@gmail.com Thanks
#2558251 - 10/03/18 12:16 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
luckydave Offline
BIG BLOCK HEAD BOLTS WOW!!
I will ship as many as will fit into a medium flat rate box ( 70 lb limit) the tape will cost more than the shipping so....
enough to last you a life time and help on those resto's where you want a matching set correct for your build
$55 shipped FREE!!!! email only dusterdave173@gmail.com
Description: 4
Edited by crabman173 (10/03/18 12:29 PM)
#2558252 - 10/03/18 12:17 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
luckydave Offline
The Good big block water pump housings I have three
$30 each shipped free!!!!! dusterdave173@gmail.com Thanks
Description: 2
#2558259 - 10/03/18 12:26 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
luckydave Offline
Big Block and Small Block
LOT of rocker adjusters and nuts--great spares!!!! Some of everything Harland, Indy, Crane etc get them all $50 shipped FREE dusterdave173@gmail.com
Description: 7
Edited by crabman173 (10/03/18 12:28 PM)
#2558459 - 10/03/18 03:41 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: Joesixpack]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
WILL NOT FIT ANY 1965 DODGE POLARA, MONACO,OR CHRYSLER 300
NEW USA MADE ENGINE MOUNTING BRACKETS(MOTOR MOUNTS)
THESE ARE THE ENGINE MOUNTING BRACKETS THAT BOLT TO THE EARS OF YOUR ENGINE BLOCK
THEY ARE EXACT DUPLICATES OF THE FACTORY BIG BLOCK MOUNTS
THEY INCLUDE GRADE 8 ATTACHING BOLTS, NUTS, WASHERS
THEY ARE POWDERCOATED SEMI GLOSS BLACK
THEY ARE BRAND NEW!
THEY WILL FIT ALL V8 K-FRAMES (WONT FIT 6 CYL KFRAMES)
FIT
1963-1964 DODGE POLARA,330/440 MODELS WITH AN ORIGINAL V8 K-FRAME
1965 DODGE CORONET WITH A V8 K-FRAME
WONT FIT ANY 66 AND UP B-BODY KFRAME
WONT FIT ANY 1965 DODGE POLARA OR MONACO
YES 273-318S USE THE SAME K-FRAME AS THE 361-383-413-426WS
$90 plus $14 usps medium flat rate box
cowgerwilliam035@gmail.com
#2558511 - 10/03/18 04:30 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: Joesixpack]
Joesixpack Offline
2 NEW big block v8 distributor mounting plates,electronic ignition magnetic pick ups W/HARNESS&PLUG, 2 reluctor wheels,2 locating pins,1 shim, made in the usa nors
PICS WONT LOAD TOO BIG EMAIL ME FOR PICS
$50 mailed
Edited by Joesixpack (10/04/18 10:05 AM)
#2558541 - 10/03/18 05:53 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
bbodee Offline
Loc: CA
NEW BCR 1/2 inch Girdle kit, SOLD thanks Moparts
Used MSD 8536 distributor Sold thanks Moparts
Brand new, not in box, Howards timing set billet steel #94340. Sold
Chrome, made in USA Mopar P4120534 ignition control unit. SOLD. Thanks Moparts
Please feel free to ask for any additional pics/info. Thanks for the ad Moparts
Edited by bbodee (10/12/18 08:30 PM)
#2558863 - 10/04/18 10:45 AM Fresh 540 Mega Block 800 plus hp $17500/obo [Re: moparts]
440PURSUIT Offline
Loc: DC, MD Suburbs
Just Freshened
https://www.youtube.com/watch?v=LqSwun-xYEU
14:1 JE Pistons
Total Seal 1/16 1/16 3/16 File Fit Moly
BME Rods 7.10 426 Forgings
Mopar Mega Block 4.380 bore
Block CNC Machined for lightening. No Motor mounts
4.500 Stroke Eagle
O Ringed -Copper Gaskets
Indy 572-13
Jesel Rockers 1.7
Spray Bar Indy Valve Covers
Cam Motion Solid Roller
R2826-2862-11 281/290 799/750 107/115 lobe Center intalled at 108
Super Damper
Double Roller Chain
Dual Line Milodon Swinging Pickup
8 Bolt Crank with BM Flexpalte
Drilled for Chevy Starter
Indy 4500 Intake
CSI Starter
Motor Plate/Mid Plate
MSD ProBillet
http://s1036.photobucket.com/user/mp440/library/540%20Race?sort=3&page=1
$17500/ offers trades
Edited by 440PURSUIT (10/22/18 07:13 PM)
1969 Hemi Charger R/T,
1969 Charger RT Clone
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1969 Dart GTS 340 Convert
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Road Runner 340-4
1972 Charger Rallye 400-4
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1967 A100
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
2006 Dodge Magnum 5.7
2017 3500 Dually
#2559445 - 10/05/18 12:48 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
Slap Shot Offline
Loc: Dover,Pa
sold
#2559571 - 10/05/18 04:01 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
SOLD - BB rod bearings. Standard size. New in box but been sitting on the shelf for a few years. $30 for the set of 8 plus shipping. PayPal preferred. PM me on the board.
Edited by AndyF (10/26/18 03:18 PM)
#2559873 - 10/06/18 11:39 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
furious70 Offline
Loc: IL
9/25/69 HP 383 shortblock $350obo
bare magged 452 castings, $100
mallory yc-365-hp distributor $50
in eastern Iowa but can get to Chicago
Edited by furious70 (10/06/18 11:41 AM)
25,700 Registered Members
196,767 Topics
When you are bored in the Iowa winter. Mopar related!
by tboomer
01/20/19 10:57 AM
Best Way to Strip and Refinish Steel Rim
by floyd
01/20/19 10:49 AM
2002 24valve, I need a little more power
by RV2
01/20/19 10:44 AM
Help ID Manual Trans Pedals
by floyd
01/20/19 10:42 AM
