Page 1 of 4 1 2 3 4 >
#2557546 - 10/02/18 09:31 AM For Sale - Small Block Engine - 4th Quarter
moparts Offline
#2557673 - 10/02/18 12:34 PM QFT/Proform-type "950" 1.45" v 4150 Carb [Re: moparts]
BradH Offline
Loc: Valhalla... eventually
Please refer to advertisement in Race Parts for Sale: HERE!
#2557753 - 10/02/18 02:42 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
Original Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $35
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
Original Cal Custom 9" finned air cleaner top and base. No filter. $75
AC alternator bracket from a mid 70s 360. $15
Good used intake to water pump crossover hose from a mid 70s 360 with AC. $5
Mr. Gasket 1" thick carb spacer. $15
Small block passenger side biscuit motor mount bracket. $30
137 New Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
New Cloyes C-3028 small block Mopar timing chain. $25
Carb. throttle linkage stud. $10
Pair of factory small block valve covers. Not sure of year. Nice shape. $75
Alternator date coded 1965. $60
Email: gt340 @ yahoo.com
#2558099 - 10/03/18 02:50 AM Small block 273, 318, 340, 360 Weiand aluminum valve covers [Re: moparts]
Memongo Offline
Loc: Fenton, MI
Small block 273, 318, 340, 360 Weiand Aluminum Valve Covers. $100. Call Steve 810-629-1097.
Edited by Memongo (10/03/18 02:50 AM)
#2558752 - 10/04/18 03:04 AM Casler small block headers, fits 273, 318, 340 and 360 motor [Re: moparts]
Memongo Offline
Loc: Fenton, MI
Casler small block headers, will fit 273, 318, 340 and 360 motors. Used, in good condition. $200. Call Steve 810-629-1097.
#2558997 - 10/04/18 04:39 PM Re: 360 aftermarket truck oil pan [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
I have for sale a 360 truck oil pan. I got this pan with a bunch of other stuff that I bought a while ago. The pan is from China but looks to be made with fairly heavy metal. From the looks of it, it appears to have been installed on an engine at one time but no oil has ever been put into it so it may very well have never been used. I would like to get $45 for it plus the shipping. No dip stick or pickup though.
Edison, NJ
rider1454 at aol.com
#2559773 - 10/06/18 08:10 AM Re: 360 aftermarket truck oil pan [Re: moparts]
69swinger340 Offline
Loc: Hillsdale,Mi
70 340 long block complete from intake to oil pan. X heads and 273 rockers.
$2750 obo
Email is best. Tsawyer340@gmail.com
Jonesville, mi
*69 swinger 340 4spd *70 T/A 340+6pk 4spd
#2560761 - 10/08/18 09:03 AM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
Pale_Roader Offline
Swears too much
Loc: the frozen wastes...
5.2/5.9 Magnum speed parts
Crosswind Magnum swap intake (RPM Air-Gap), brand new in box. $150USD/200Cdn
Bullet Magnum hyd roller cam (custom), 235/245@.050, .555lift, 108 lobe sep, Designed for big lope, big power, but mild enough for an unbuilt engine, and easy on springs. $260USD/$350Cdn
Steel shim head gaskets .215" compressed ht, 'very last pair available anywhere'. $75USD/$100Cdn
Aluminum water pump/crank pulleys, slight underdrive. $35USD/$55Cdn
Milodon (or Moroso?) solid (LA) engine mounts. $25USD/$30Cdn
Dougs 453r SBM headers for B/E body (possibly others?). Older design, but still modern style that DONT go underneath suspension. $150USD/$200Cdn
I can separate headers/mounts from the rest if you're not building a car, but i'd rather keep the rest together.
Looking for $560USD/$750Cdn for all.
Also have a Luk clutch kit for SBM, brand new in box. $150USD/$200Cdn
Located in British Columbia, an hour East ov Vancouver.
PM here for details.
Thanks.
Edited by Pale_Roader (12/13/18 08:25 AM)
#2560933 - 10/08/18 01:42 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: Pale_Roader]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
273-318-340-360 new electronic ignition/single point v8 caps and rotors
new black,aluminum insert hd ribbed cap,usa made$10ea
new,black,copperor brass insert hd ribbed cap,usa made$20 w/ a rotor
black mallory brass insert hd cap&mallory rotor$30
cowgerwilliam035@gmail.com
#2560991 - 10/08/18 03:40 PM Fresh black wrinkle powder coated MT valve covers [Re: Joesixpack]
dodge turbo Offline
Loc: Dirty Dena, Maryland
Message me for pictures. It will not let me add them
$120 OBO
Edited by dodge turbo (10/10/18 04:11 PM)
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
#2562544 - 10/11/18 04:42 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
727builder Offline
Loc: Tennessee
(((( SOLD )))) Like new 360 Moroso 8qt deep oil pan and Pick-up tube. Was used about 2 months on 408. Was too deep for the customer. Never bottomed out. Cost over $300 from summit. Take $225 with free delivery to the lower 48.
Can pm me here, Or call or text for quicker reply.
Can send more pics...
Carl 423-402-6752
Thanks Moparts!!
Edited by 727builder (11/26/18 10:44 AM)
#2563864 - 10/14/18 12:27 PM Small Block 360, Short Block [Re: moparts]
392Hemi Offline
Loc: Michigan
I am going GenIII and need to sell before I buy new motor. Open to trades pending what you have. Only want to trade for Gen III motor parts.
Prefer Complete motor(Running)
360 Block
Cast Crank (4.060 inch Bore 4 inch Stroke)
Eagle SIR Rods
Wiseco Flat Top Pistons
12.0 to 1 Compression with 64cc heads
Manley High Volume Oil Pump
8 qt. Oil Pan
SFI approved Balancer
Short Block $2000.00 OR BEST OFFER
I will separate Crank, Rods and Pistons from Block
PM me for info and short block is in the car and ran good
Edited by 392Hemi (12/30/18 05:51 PM)
74 Dart Sport
Recreation to Gen3 Power!!
ET's coming soon
#2563896 - 10/14/18 01:27 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: schmitty]
moparjohn Offline
Loc: N.W. INDIANA
Recently I have finished bead blasting and priming my extra water pump pullies. I am starting to look up the ones that have part numbers. So I have found a 2951836 that is for 1970 Challenger T/A's and AAR CUDA's with the 340 engine. The price is $40.00 plus shipping. If your interested contact me at: moparjohn@frontier.com with your zip.
If you are looking for a water pump pulley let me know the diameter and how deep. I have many to choose from.
Thanks!
#2564245 - 10/15/18 02:01 AM Holley 4150 carburetor 750 double pumper [Re: moparts]
Memongo Offline
Loc: Fenton, MI
Holley 4150 carburetor 750 double pumper with electric choke, used, $250. Call Steve, 810-629-1097.
#2564298 - 10/15/18 08:41 AM Re: QFT/Proform-type "950" 1.45" v 4150 Carb [Re: BradH]
gtxblu Offline
I have a complete 1966 273 engine that is seized up. Pulled it last week out of my satellite. It is missing the carb and one exhaust manifold. First $100.00 takes it. 1-734-775-0738. located outside of detroit.
#2564369 - 10/15/18 11:01 AM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
LemonTwiist Offline
Loc: Mechanicsburg, PA
FOR SALE: Used metering block #6512 #4780. It still has the power valve, jets, and needle adjusting screws. The part numbers have been sanded off, but can still be seen in the casting. PRICE $35.00 Plus $6.00 postage
Edited by LemonTwiist (10/15/18 11:02 AM)
#2565007 - 10/16/18 05:01 PM T/a block heads rockers and intake [Re: moparts]
n96cuda Offline
Loc: indiana
340 t/a block, matching heads complete with rockers,shafts,valves and springs. original 6 pack intake. $6500 for everything
ebodyjoe@aol.com
765-618-2037
#2565786 - 10/18/18 03:58 AM 1970 318 engine [Re: moparts]
BLACKHEMIRR Offline
1970 318 engine. Excellent running engine in good condition. Has E-body Hooker competition headers and an LD 340 intake with an Edelbrock AFB carb. Original distributor. I do not believe the engine has ever been apart. Engine has been in a 71 Cuda for many years and is clean and detailed. Engine is located in S.E. PA. I also have the original 2 bbl intake, carb, and air cleaner to go with it. Asking $500. PM me here if interested. Engine is in S.E. PA. Thanks for the ad.
#2566643 - 10/19/18 06:58 PM Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts]
ValiantRich Offline
Loc: Long Island, NY
Main bearings for small block 273, 318, or 340. Mopar Performance part#P5249056. These are Clevite bearings for .001 additional clearance. 4 sets available. $50 each. rich1981@optonline.net
Edited by ValiantRich (11/16/18 11:44 AM)
#2566871 - 10/20/18 09:37 AM Re: For Sale - Small Block Engine - 4th Quarter [Re: ValiantRich]
SSHemi364 Offline
Loc: OHIO
Complete 6 pack set up for 340. Come with air cleaner, base, carbs, linkage, fuel lines, and intake. All together $2500 or best offer.
Email me if interested josephdepillo@gmail.com
25,700 Registered Members
196,768 Topics
340 6 BBL intake id ?
by moparx
Today at 12:02 PM
When you are bored in the Iowa winter. Mopar related!
by tboomer
Today at 10:57 AM
Best Way to Strip and Refinish Steel Rim
by floyd
Today at 10:49 AM
2002 24valve, I need a little more power
by RV2
Today at 10:44 AM
