Re: Four point harnesses - what cha have?
[Re: Mattax]
#2557251
10/01/18 09:21 PM
10/01/18 09:21 PM
Posts: 22,695 Bitopia
jcc
Bitopia
"* Possibility the shoulder straps pull the center of the seat belt up as the torso moves forward. This can allow the hips an dbody to slip under the lap belt ('submarining'). I assume Schroth figured out an attachment location etc to prevent this, but again worth checking into."
It's not the submaring that is the problem in upright sedan seating, although that is the common thought, the hips/pelvis is the strongest point in your body, and able absorb huge forces relatively, when the lap belt rises off the pelvis in a forward impact, from the chest straining the shoulder harnesses where they connect to the lap belt, the lap belt is now up in the rather soft fragile belly area, that area is not good at restraining your body mass, and not good at absorbing huge forces (Liver, kidney's, intestines, stomach etc.) I would NEVER wear a 4 point. An OEM 3 point shoulder belt does not have this issue near as much.
[Re: Mattax]
#2557339
10/01/18 11:56 PM
10/01/18 11:56 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
AFAIK there's only one that claims to meet DOT standards for street use. Shroth (sp?). I called about it when they first came out. At least at that time, they would not fit the standard Mopar and GM seatbelt bolts of the 60s and 70s. (Nor do most 5 and 6 point harness - the holes have to be opened up). Do your homework. The plus side is obvious. They can be used with a regular car seat. The neg side is harder to nail down. I'll mention a couple potentials I'm aware of. * Last year I read a regulation were 4 points were prohibited, but I can't recall if this was NJMP's interpretation or NJ State racing regs themselves. See what's allowed where you intend to play (and drive). * Sternum damage in a forward accident. A mid chest cross strap would might reduce that but its probably been tested and modelled. Worth finding out. * Possibility the shoulder straps pull the center of the seat belt up as the torso moves forward. This can allow the hips an dbody to slip under the lap belt ('submarining'). I assume Schroth figured out an attachment location etc to prevent this, but again worth checking into.
If you go with a racing seat, there will be a slot for anti-submarine belts. If you go with a more supportive automotive seat, maybe you'll be happier with the 3 point than you are now.
I have a lap belt only now, and that's DOT compliant...anything is an improvement. I am not sure a factory 3-point retractable setup is much better without a modern pyrotechnic tensioner on it, especially in a side impact.
[Re: GoodysGotaCuda]
#2557437
10/02/18 08:25 AM
10/02/18 08:25 AM
Posts: 2,463 Answering the call of the wild
ThermoQuad
I lived with a 5pt set up on Corbeau GT seats in a very wicked car that got driven lot's of places besides the road course 100 miles away. I also set up project black n blue [70 Charger RT] the same way however the shoulder belts were made removable for the child in the back seat. The performance seat alone keeps you in the seat. Add the proper lap belt for street driving and for an old car being driven normally you are a-ok. My opinion from owning and building old but very very fast cars is if you have such a beast you need seats and seat belts. Period. I ran with the lap belt only and if things were going to heat up everything was buckled. It is fun is to reach over and check the belts on the whining passenger as you get ready to give them a jet ride. Now trying to have rear seat passengers and shoulder belts is a problem so you cannot have your cake and eat it too as shoulder belts need to be with 12 degrees of level at the shoulders so tying them to the rear seat belt bolts is a big no no. Cage bar or package tray area. I installed the shoulder belts in both cars to a fabricated reinforced package tray. Both cars were examined closely at my road course tech inspection and the installs given 2 thumbs up.
#2557738
10/02/18 04:19 PM
10/02/18 04:19 PM
Posts: 403 Colorado front range
BcudaChris
Goody,
There was an article in one either Hot Rod, Car Craft or one of the Mopar offerings within the last year. I'm sure I still have the rag and will try and locate issue/date info.
This guy had a max effort, stock based multi purpose AAR (Tor Reds no less, no cage, multi purpose being key to the max effort and not a pro touring type of car). He is an engineer, and while no details were given, he had rigged up a removable anchor bar that spanned the rear seat when installed and served as an anchor for the shoulders and crotch strap of a 5 point setup for his track confit. I didn't notice the non-track seat belt solution however.
I have installed an XV 3pt setup. It is amazing, relatively speaking. They are about the same level of hassle as the belts in my 01 Bullit that is my grocery getter/parts store runner, daily driver.
Also, I run around with a kid seat in the back of my Barracuda as well. I use the lap belt and rigged a setup using a carribeaner (sp) to hook the head strap to the spare tire hold down. Works well. Not like having proper anchor points well, but as good as the a fore mentioned Mustang with a head strap anchor point. Certainly better than anything us 70's 80's kids grew up with.
As I recall, with a 1.25" sway bar, he ripped the driver's LCA sway bar tab open at the bushing eye when running the car for the magazine story.
#2558003
10/02/18 10:58 PM
10/02/18 10:58 PM
jcc
Bitopia
The non-retractable 72 shoulder belt is not practical, nor very effective with the high roof mounting point [no down-leg] Care to explain this shortcoming?
[Re: jcc]
#2559794
10/06/18 11:18 AM
10/06/18 11:18 AM
jcc
Bitopia
Received my latest monthly issue of industry PRI magazine on Wed. I read it last night, it had an article on race car safety devices. On seat belts, it almost seemed like they copied my post here. My question in the previous post was about I suspect what the Op thinks the intended purpose is for shoulder harnesses. The article addresses that aspect. One thing I read for the first time, the designers are leaning away from 3" belts, everywhere, my biggest surprise was going to a 2" vs 3" lapbelt, reason being, the wider belt starts to encroach on the vital belly area. I'll post later more details on the article, issue, page and author. https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/1551214/Searchpage/5/Main/137126/Words/+%2Bbelt/Search/true/re-seat-belt-recomendations.html#Post1551214
