Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing*
[Re: GoodysGotaCuda]
#2559125
10/04/18 11:08 PM
10/04/18 11:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Those of you thinking fuel issue, or cam timing I think miss one crucial fact. His video is with no load on it.
I cannot imagine a fueling issue that would cause it to do this unless it was massively rich and it'd be blowing great clouds of black smoke.
I cannot imagine a cam timing issue that would let it run at all and do this.
It almost has to be ignition.
#2559148
10/04/18 11:51 PM
10/04/18 11:51 PM
Posts: 20,163 Park Forest, IL
slantzilla
Park Forest, IL
There was a thread on here a couple years ago about a car going super lean in the upper rpm range. I can't recall if it was laying down like this one though. It turned out to be a fuel line sucking shut back by the tank.
This one still seems like valve springs or lifters though.
[Re: Guitar Jones]
#2559173
10/05/18 12:34 AM
10/05/18 12:34 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I'm qualified, and infinitely more qualified than you Mr. Construction worker. Well, that was pretty rude. I can degree a cam...Can you build a house? Lay out a frame? Calculate roof pitch and cut rafters that fit? I would be very surprised to hear that you can but since this is a car forum, lets focus on that instead of insulting another mans trade. You made it clear that you thought that degreeing a cam is pointless. Maybe it is to YOU but if nothing else, it can rule out an area that allows you to focus elsewhere.
[Re: Kern Dog]
#2559187
10/05/18 12:59 AM
10/05/18 12:59 AM
Posts: 4,457 Washington
madscientist
Washington
I'm qualified, and infinitely more qualified than you Mr. Construction worker. Well, that was pretty rude. I can degree a cam...Can you build a house? Lay out a frame? Calculate roof pitch and cut rafters that fit? I would be very surprised to hear that you can but since this is a car forum, lets focus on that instead of insulting another mans trade. You made it clear that you thought that degreeing a cam is pointless. Maybe it is to YOU but if nothing else, it can rule out an area that allows you to focus elsewhere. Don't let guitar dude get to you. He was a line mechanic and not an engine builder or a machinist and they ain't the same thing. IDGAF if Chrysler, or GM or ford or anyone else lines the cam dot to dot. The factory didn't give a single [censored] how they ran when they left the factory. They didn't care. It's quick and dirty to dot to dot and it shows lack of experience. To the OP. I don't really care what is wrong with your engine. What I'm saying is to do the job correctly, and eliminating potential problems you need to STOP and degree the cam. It's that simple. You can be a keyboard builder who cuts corners, or, you can do the [censored] correctly. Degree the cam.
[Re: madscientist]
#2559212
10/05/18 01:54 AM
10/05/18 01:54 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Any chance there are weak grounds in the system?
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: blown340]
#2559260
10/05/18 05:34 AM
10/05/18 05:34 AM
Posts: 20,625 in a cattle trailer down by th...
Guitar Jones
Any chance there are weak grounds in the system? There is a huge chance of this. It's probably the single most frequent problem seen in these old trucks.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
#2559295
10/05/18 10:15 AM
10/05/18 10:15 AM
Guitar Jones
Truck is running well now as it appears to have been a combination of things.
Thanks for the help and drama! Soo, you are just going to keep it to yourself?
#2559298
10/05/18 10:25 AM
10/05/18 10:25 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Tick Tick Tick
That's more drama until
Let the truth bee told !!!
Lol
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
#2559305
10/05/18 10:39 AM
10/05/18 10:39 AM
DemonDuster
Hit a wall ? gotta hurt... Baad Ground volt drop, solution buy a mustang. Junk dat cam too an decree it already, Kongratz, I luv draamma. (Glad you got it figured out.)
[Re: Guitar Jones]
#2559309
10/05/18 10:52 AM
10/05/18 10:52 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks for the help and drama! Soo, you are just going to keep it to yourself? I degreed the cam and now my exhaust smells like fresh baked cookies and unicorns lead the way everywhere I go.
#2559312
10/05/18 10:56 AM
10/05/18 10:56 AM
Guitar Jones
[Re: Guitar Jones]
#2559315
10/05/18 11:11 AM
10/05/18 11:11 AM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Filled the gas tank, corrected not having full throttle, cleaned the batterery terminals, ohhhh and he readjusted the rev limiter. LOL.
[Re: pittsburghracer]
#2559324
10/05/18 11:31 AM
10/05/18 11:31 AM
Guitar Jones
Filled the gas tank, corrected not having full throttle, cleaned the batterery terminals, ohhhh and he readjusted the rev limiter. LOL. So are you telling me that degreeing the cam is not going to give me the desired fresh baked cookie and unicorn effect?!? I'm so disappointed.
#2559333
10/05/18 11:50 AM
10/05/18 11:50 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Thanks for the help and drama! That’s the kind of post I’d expect to see if one were a little embarrassed about what the problem actually was. And....... doesn’t help the next guy who might find themselves in the same situation.
