Using a 9.25" truck axle in an E/B-body? #255520
03/16/09 10:34 AM
03/16/09 10:34 AM
Toronto (YYZ) Ontario
YYZ Offline OP
YYZ  Offline OP
After pricing out various 8 3/4" axle components, and getting a bit of sticker shock, I'm wondering: How readily could one swap a 9 1/4" late model truck axle (Durango/Dakota) into our older cars?
Granted, you'd need custom axle shafts with a 5 bolt pattern (about $4-500), but the axle housing and gears are relatively plentiful and cheap. Furthermore, most of them came in very desirable gear ratios of 3.55 or 3.92 along with the Sure-Grip
Thoughts?
Re: Using a 9.25" truck axle in an E/B-body? [Re: YYZ] #255521
03/16/09 11:44 AM
03/16/09 11:44 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Well B bodies from 74 up as well as C bodies did have the 9.25 available, I've got one in my sig car. Seems to me it'd be much cheaper and easier to score one of those and put it in. If you're going through the time, money and hassle of converting a truck rear end over for your car, you might as well get a junkyard Dana 60 from a truck and convert that over. That effort on a 9.25 wouldn't really be worth it.
Re: Using a 9.25" truck axle in an E/B-body? [Re: DaytonaTurbo] #255522
03/16/09 12:03 PM
03/16/09 12:03 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
The 9 1/4 is a C-clip rear. I would never use it
in a car or truck where you plan on bangin gears
or any posi hard launches. Break an axle, and
out it comes. Unless you looking for 3.08 - 3.23
gears, do up a Dana 60 and never worry about your rear again.
If you must do a 9 1/4, then have the different
ends welded on. If you break an axle it stays
in and doesn't wreck your 1/4 panel.
Then you can run a 2.96 gear a fly down the freeway.
Snap your neck, mega G-force launch, is all I want!
Re: Using a 9.25" truck axle in an E/B-body? [Re: BDS871Cuda] #255523
03/16/09 12:14 PM
03/16/09 12:14 PM
Manitoba, Canada
Manitoba, Canada
It really doesn't look like it'd be that hard to weld up a jig to keep the rear axle in place. If you have rear discs the rear axle won't go anywhere or fab up a little guard to hold the drum from sliding out in the even of a c-clip failure. Plus you don't hear about mopar 9.25 c clip issues like you do with the brand X guys.
Re: Using a 9.25" truck axle in an E/B-body? [Re: DaytonaTurbo] #255524
03/16/09 12:31 PM
03/16/09 12:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You could always go w/ a Furd 9". I still think you can get a 8.75 case for $50 and a decent pumpkin for around $4-500.
Re: Using a 9.25" truck axle in an E/B-body? [Re: Mr.Yuck] #255525
03/16/09 12:47 PM
03/16/09 12:47 PM
YYZ Offline OP
YYZ  Offline OP
I wasn't looking at any change to the axle housing (other than perches) because the width is similar.
By the time one builds and freshens an 8 3/4" properly, you might as well buy a built Dana 60.
However, I don't want quite that much unsprung weight under the back end of the car
Re: Using a 9.25" truck axle in an E/B-body? [Re: YYZ] #255526
03/16/09 12:51 PM
03/16/09 12:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what are you trying to do? A backbraced 8.75 is pretty strong. You can buy a new ring/pinion for around $200 and the clutch kit (assuming it's a 472) for $99 that should get you a pretty strong set up. Or you can look around and find a used pig for around 4-500. A Dana is about $1600.
Re: Using a 9.25" truck axle in an E/B-body? [Re: DaytonaTurbo] #255527
03/16/09 01:26 PM
03/16/09 01:26 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
look for a big block or E58 cordoba (late B) or any mid '70's bigblock C body, they should all have 9 14's. they'll be 2" wider than a E body rear and the perches will be spaced 1" further apart, though.
the extra width would probably allow you to run late model mustang rims without spacers.
2017 Grand Cherokee Overland
