Re: 1970 steering columns
[Re: Alaskan_TA]
#2554787
09/25/18 11:02 PM
09/25/18 11:02 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
'70 columns are unique.
Even for 1970 B-body there were different versions.
Column shift.
Manual shift / console shift.
Manual vs. power steering.
So what does your car have? How the hell did i make a post about steering columns and not include that hahah, its a console shift and has power steering.
[Re: 70charger512]
#2555628
09/27/18 05:51 PM
09/27/18 05:51 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Column shift.
So what does your car have? How the hell did i make a post about steering columns and not include that hahah, its a console shift and has power steering. If you have (or can find) one from a column shift car, the parts are available via the aftermarket to convert it.
[Re: Alaskan_TA]
#2555637
09/27/18 06:21 PM
09/27/18 06:21 PM
Posts: 2,366 Wheatfield, NY
Cuda340
Wheatfield, NY
This is from my manual steer / manual gear 70 Bee. Circled in red is where the lower plastic bushing goes on the lockout tube. There really is no lower bearing.
[Re: Cuda340]
#2555704
09/27/18 09:27 PM
09/27/18 09:27 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
This is from my manual steer / manual gear 70 Bee. Circled in red is where the lower plastic bushing goes on the lockout tube. There really is no lower bearing. And its the same as power steering column im assuming? I couldve sworn in the manual it showed a longer tube that surrounded the shift tube and the bearing, with the bearing after the shift tube. Also, is it not still a screw in bearing? If u have a pic of the bearing could u post that too? Isnt there supposed to be a bearing in the lockout tube for the shaft?
[Re: 70charger512]
#2555743
09/27/18 11:11 PM
09/27/18 11:11 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I have only ever seen a plastic "bushing"... Never a bearing...but my 70 is power steering... I recently had to build a column for the Duster that we switched from power steering to manual...The bottom half of both steering shafts were identical...The top half of the PS column was shorter. I'd imagine that also applies to B Bodies...heck they may all be the same for that matter... The splined couplers are different but the shaft itself was the same...At least on an A Body...
The pic is not great but it shows how far my column sticks out past the firewall and rough length of the exposed tube...
...FAFO...
[Re: 70charger512]
#2555749
09/27/18 11:19 PM
09/27/18 11:19 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
The lockout lever/tube is the same on all the '70 b-body columns. The columns are really identical, power/manual & column/floor shift except for the lower collar I believe + some misc. stuff like the "PRNDL". This part going from memory about 5 yrs. ago, but I believe the bottom end of the column has a big fat plastic "insert bushing" & there's a little "flip-over wire clip" that goes into a slot on that bushing to hold if from sliding up/down in the tube.
Geez...I'd send you pictures, but my phone is busted. If it looks like it fits in there, right color vs. interior, it's probably the right one. A '71 has a "key release slide thing" right by the key. The 68/69 (& maybe earlier years the same column too?) have no key hole in the column. The '70 has a key in the column & no slide "key release slide thing"..... I'm an idiot....just look at cuda340's picture....like that.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: skicker]
#2555999
09/28/18 02:41 PM
09/28/18 02:41 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
The pic is not great but it shows how far my column sticks out past the firewall and rough length of the exposed tube... I believe you know what you’re talking about, my confusion came from when my bearing came off (it was a completely wrong bearing screwed into the shift lever.). I obviously ordered a “correct” one from year one. Im assuming you guys know what im talking about, this came with two screws. I thought this had to be wrong but somewhere in the manual theres a pic of the cover tube going over the shift lever (with a gap for it to move) and it showed the bearing fitting in there. If anyone knows what im talking about please explain.
[Re: 70charger512]
#2556026
09/28/18 04:24 PM
09/28/18 04:24 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
I'm having a hard time understanding...could you post a picture or two?
[Re: PurpleBeeper]
#2556125
09/28/18 10:41 PM
09/28/18 10:41 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
I'm having a hard time understanding...could you post a picture or two? I will as soon as im on my laptop, im out on my phone right now. Its in the 1970 charger/coronet service manual.
[Re: 70runner]
#2556148
09/29/18 12:09 AM
09/29/18 12:09 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
OE from 70 Coronet, PS, console, restored for my 70RR. No bearing at lower end, just a plastic spacer. There is a shaft bearing at the upper end. In the second picture it looks like the shaft is free to move around in the tube. How does it stay stable on the lower end? I have two screenshots, turns out the second one is for column shift manuals, but i'm not sure about the first (unless its the same). It's confusing because they put multiple pictures on the same page in random order without labeling what type its from.
[Re: 70charger512]
#2556151
09/29/18 12:19 AM
09/29/18 12:19 AM
Posts: 8,392 Highland, MI.
Sunroofcuda
Highland, MI.
Speaking of steering columns, we found a LOADED PCP 1971 Charger R/T in a junkyard in Abilene, TX. back in 1984 that was a 440-4 car with auto column shift & tilt steering. I've never seen another B-Body with tilt steering.
[Re: NANKET]
#2556166
09/29/18 02:32 AM
09/29/18 02:32 AM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
The black & white photo above shows a 3 speed manual shift column. Many times these are very different and beefed up to take the constant abuse from shifting all the time. So there is no lower bearing? How does the shaft not move around? In 70runner’s pic the shaft looks like it has alot of free room.
[Re: Sunroofcuda]
#2556182
09/29/18 05:18 AM
09/29/18 05:18 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Speaking of steering columns, we found a LOADED PCP 1971 Charger R/T in a junkyard in Abilene, TX. back in 1984 that was a 440-4 car with auto column shift & tilt steering. I've never seen another B-Body with tilt steering. 71s and 72s got that option
[Re: 70charger512]
#2556430
09/29/18 10:35 PM
09/29/18 10:35 PM
skicker
"The Champ"
"The Champ"
Western Md.
[quote=NANKET] So there is no lower bearing? How does the shaft not move around? In 70runner’s pic the shaft looks like it has alot of free room. The shaft gets attached to the box which is a fixed object. I usually put the column in and snug up the two nuts that go over the studs at the bottom rear of the dash. I then attach the bottom plate and then slide it around until the steering shaft is centered inside the column. (end of the tube sticking thru the firewall)Check it for placement front to rear and then snug up the two bolts that go into the larger plate and finishing tightening the upper column mounts. There should also be one low on passenger side that uses a bolt and is not a stud with a nut. Be sure to put the pin in the shaft coupler on the box and then just plug everything in. I modified mine to be floor shift as it was an original column shift. That's why you don't see a column shift bracket at the end of the tube on mine. In the pics of the refurbished column above you'll see a white disc that goes inside and is held in by the spring clip...That's all there is and it is a bushing for the column shift part not for the shaft part.
...FAFO...
[Re: 70charger512]
#2557154
10/01/18 06:06 PM
10/01/18 06:06 PM
Cuda340
Wheatfield, NY
Watch these short videos. The 70 B/E columns are almost identical. https://www.e-bodies.org/videos/ Also there is no lower bearing, just the lower bushing that gets clipped in place. It goes between the column and the lockout tube. As stated above, shaft can float around until it gets bolted to the steering box. Jeff
