70 Challenger passenger rear 1/4 patch panel #2553258
09/22/18 03:08 PM
09/22/18 03:08 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Need a 70 Challenger patch panel for the fwd lower section of the passenger side rear quarter panel. This is the lower section from the aft end of the passenger door jamb to the contour of the front section of the rear wheel well opening and extends up to the small lower contour body line (Not the main body line). I personally seen a patch panel which was made by Sherman. That panel was awful. The lower contour line and wheel well contour and lines did not match. Panel looked as if the drop hammer press was weak or most likely the stamping mold was not detailed. I have come across a patch panel made by Goodmark on the internet. The picture is hard to tell if it is any better than the Sherman panel. Anyone have any experience with the Goodmark repair panel? Sorry for the lengthy post.
Re: 70 Challenger passenger rear 1/4 patch panel [Re: RROD] #2553459
09/23/18 01:51 AM
09/23/18 01:51 AM
Phila
P
PhillyRag Online content
PhillyRag  Online Content
P
Phila
I'd like to know also. Need both ls/rs of these. The AMD partial rear qtr is an option. But that's wasting alot of unused metal. I can't understand why AMD doesn't offer that patch, being they already have the means to.
Re: 70 Challenger passenger rear 1/4 patch panel [Re: RROD] #2553484
09/23/18 03:01 AM
09/23/18 03:01 AM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
I agree. It would be so easy to stamp out that section. I guess that would cut into their quarter panel sells.
Re: 70 Challenger passenger rear 1/4 patch panel [Re: RROD] #2553958
09/24/18 05:21 AM
09/24/18 05:21 AM
Phila
P
P
Phila
I just used ab AMD partial panel on a 73, & then section of panel looked nice. Not very 'crisp' lines all around, but presentable. I see that lower section listed as Sherman's; not sure about quality. Guess best to view in person.
Re: 70 Challenger passenger rear 1/4 patch panel [Re: RROD] #2553996
09/24/18 10:55 AM
09/24/18 10:55 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
I have both Goodmark skins and AMD full quarters loose in my garage right now. The Goodmark stamping isn't as 'crisp' especially on that lower body line you're describing.
That being said, the goodmark panel is still a great budget friendly option, and it wouldn't bug me to use them personally.
Re: 70 Challenger passenger rear 1/4 patch panel [Re: RROD] #2554524
09/25/18 03:38 PM
09/25/18 03:38 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The goodmark full quarters are stamped much better than the skins. Just installed a pair, only issue I had with them was the trunk lid gap with was an easy fix... very little work otherwise to get straight.
Anymore I prefer to replace the full panel. If its rusted on the lower area, may not be long before it starts to bubble around the wheel well.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 70 Challenger passenger rear 1/4 patch panel [Re: RROD] #2554906
09/26/18 07:35 AM
09/26/18 07:35 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Sherman used to sell low cost panel skins/ patch panels that were basically made with a hammer and dolly. (not literally but you know what I mean) Very poor quality. The higher cost panels from AMD- Goodmark will be leaps and bounds better than what you dealt with.
Keep old mopars alive.
