Pigtail setups for trapped starters #2554291
09/25/18 12:03 AM
09/25/18 12:03 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
My starter is trapped by header tubes. Im sure this is not uncommon. I want to have a longish pigtail on the starter so i can bolt the starter in place with the wires already connected rather than trying to thread them on the lugs in that mess. Then simply plugging the pigtail in to the rest of the harness after the starter is installed..Not being a wiring guy, what is a good reliable setup or hardware to use for this? Pics would be great.
Re: Pigtail setups for trapped starters [Re: Hot 340] #2554302
09/25/18 12:20 AM
09/25/18 12:20 AM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
I like a remote post on the lt apron or firewall area. Back in its Ed Hamburger days, my Duster got a plug installed for the small starter wires, and a post on the firewall near the master cylinder.
Re: Pigtail setups for trapped starters [Re: Hot 340] #2554315
09/25/18 12:44 AM
09/25/18 12:44 AM
AndyF Offline
AndyF  Offline
I use a Ford solenoid so the two posts get tied together. I used a thick piece of copper to tie the posts and then a pressed in stud for the cable attach. I can bolt all of this to the starter and slide it in pre-assembled.
Re: Pigtail setups for trapped starters [Re: AndyF] #2554386
09/25/18 10:35 AM
09/25/18 10:35 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i just put my wires on first,feed them where they need to go and bolt he starter on shruggyeasy peasey
