Axle companion flange tool ? #2554036
09/24/18 12:27 PM
09/24/18 12:27 PM
Chicago suburbs
dartgame Offline OP
dartgame  Offline OP
Chicago suburbs
Planning a rebuild of an 8 1/4 axle and need a tool to hold the companion flange while tightening the pinion nut. My buddy that had a home Hand made tool moved away. His was a flat plate of 3/8 steel with the flange shape cut in it and a long piece of steel heavy round stock welded on to it. Any suggestions where to borrow or buy one ?
Re: Axle companion flange tool ? [Re: dartgame] #2554042
09/24/18 12:37 PM
09/24/18 12:37 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Re: Axle companion flange tool ? [Re: dartgame] #2554044
09/24/18 12:37 PM
09/24/18 12:37 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Either make one or I would try to use a 48" pipe wrench to hold the pinion flange.
I have rebuild many rear ends and never used a tool like that. I used what was handy to hold the pinion when tightening the pinion nut. Most times I used a impact and holding the pinion was not a big deal.
Re: Axle companion flange tool ? [Re: dartgame] #2554061
09/24/18 01:32 PM
09/24/18 01:32 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Pinion yoke holder and puller $28.99
https://www.summitracing.com/parts/rat-18002
Re: Axle companion flange tool ? [Re: dartgame] #2554279
09/24/18 11:17 PM
09/24/18 11:17 PM
Cincinnati, Ohio
Cincinnati, Ohio
I forgot I own this to torque pinion nuts on dragster rear ends. The tool is on the left.
