Re: Dyno guess 440 stroker
[Re: CSK]
#2553336
09/22/18 07:29 PM
09/22/18 07:29 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Did I read that right. .070 over 440 block.
[Re: sogtx]
#2553393
09/22/18 10:41 PM
09/22/18 10:41 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Need real/complete cam specs.
My guess is, it will make peak power right before the valvetrain gets unhappy, unless the duration is really short.
[Re: BSB67]
#2553432
09/23/18 12:15 AM
09/23/18 12:15 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Between 525 and 650 HP, depending on the cam. You took my guess With headers it should make easy 575-600 with almost any mild performance cam
2 kids and a dog
[Re: 383man]
#2553570
09/23/18 12:07 PM
09/23/18 12:07 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
First pull resulted in poor attachment to dyno Fabricating new mounts .. may have been tractor supply grade 8 Constantly learning and regaining common sense . Lol
[Re: sogtx]
#2553591
09/23/18 12:52 PM
09/23/18 12:52 PM
Posts: 5,160 Texas
dannysbee
Texas
A fat bar with a couple of holes going to the lug on the right above your mount might help. That would tiie your mount to a second lug.
Getting old just means you were smarter than some and luckier than others.
[Re: sogtx]
#2553614
09/23/18 01:42 PM
09/23/18 01:42 PM
sogtx
upstate western ny
New mounts fabbed Uncorrected hp 672 Centers 65 Outboards 89/91 staggered Time to play with jetting and timing and Secondary springs
Lean in middle due to six pack bog
Rejetting to 92/94 Keeping timing at 35
Wish i could poke holes in my nice ttis and do individual EGTs to see if staggered jetting is valid .
I think we got a monster on 90 pump fuel .
Great guys workin with me .. takin a break and Rejetting .
[Re: sogtx]
#2553821
09/23/18 08:47 PM
09/23/18 08:47 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Performer or Performer RPM ?
Will bee interesting to see the difference with HP Manifolds
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: sogtx]
#2554035
09/24/18 12:27 PM
09/24/18 12:27 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Very nice. You know you've got nice testing conditions when corrected numbers are lower than actual.
Was the intake manifold modified?
Re: Dyno guess 440 stroker - my A12 upgrade
[Re: sogtx]
#2554055
09/24/18 12:59 PM
09/24/18 12:59 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Great results! I was surprised to see the size of the outboard main jets. Those are 10 sizes larger than what my 493 with similar sized cam & Indy EZ's likes according to my wideband. I do run the mechanical DC Holley's.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2554069
09/24/18 01:46 PM
09/24/18 01:46 PM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
Great results! I was surprised to see the size of the outboard main jets. Those are 10 sizes larger than what my 493 with similar sized cam & Indy EZ's likes according to my wideband. I do run the mechanical DC Holley's. I bet his are .089" and .091" holes in metering plates. That would be about the same as your jet sizes in metering blocks. Decades ago when I raced with the mechanical carbs at least 4 times a week I had three outer metering blocks with 78, 80,and 82 jets. I could swap them at the track a lot quicker than switching jets. Usually ran 78's and 80's on warm days and 80's and 82's on cold days. 64's or 65's in the center.
