Re: 514 on the dyno
[Re: Mopar_Rich]
#2306956
05/18/17 07:48 PM
05/18/17 07:48 PM
Posts: 2,842 Pattison Texas
CSK
Pattison Texas
Thanks Rich for the advice today on the Fast EFI Classic, you were a GREAT help!!!!
Charlie
Re: 514 on the dyno
[Re: AndyF]
#2307248
05/19/17 10:17 AM
05/19/17 10:17 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Nice work and great accomplishment!
Re: 514 on the dyno
[Re: AndyF]
#2307253
05/19/17 10:28 AM
05/19/17 10:28 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I have heard the farther up the runner you place the injector the more power you will make. But I think the gains are small and come with added work on the drive ability part of the tune.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
Re: 514 on the dyno
[Re: moparmitch]
#2307295
05/19/17 12:16 PM
05/19/17 12:16 PM
Posts: 30,945 Oregon
AndyF
CnP = Coil-Near-Plug. Similar to G3 hemi which has coil-on-plug.
Andy's setup will have the coils mounted near the plugs (maybe on the valve covers or located in an array on a bracket somewhere) with short plug wire leads for each.
Essentially, there will be 8 coils with short plug leads, 1 for for each cylinder. Yep, I'm still trying to figure it out. For the dyno engine I think I'll mount the coils on brackets on the valve covers. In the car I might put the coils on the frame rails or something like that. The nice thing about the CnP setup is that you get rid of the MSD box, the big coil the distributor and a bunch of ignition wires. From a performance standpoint, each coil only has 1/8th of the job that the big coil had before. At 7000 rpm and 15:1 compression the MSD ignition had to really work.
Re: 514 on the dyno
[Re: AndyF]
#2307306
05/19/17 12:34 PM
05/19/17 12:34 PM
Posts: 17,800 S.E. Michigan
ZIPPY
S.E. Michigan
Let me know if you want to try some 5.7 hemi coils.
Rich H.
Esse Quam Videri
Re: 514 on the dyno
[Re: AndyF]
#2308277
05/21/17 12:47 AM
05/21/17 12:47 AM
AndyF
I'm going to run the Holley smart coils which I think are basically an LS1 type coil. Here is a video of us warming up the 514 on the dyno. If you look closely you can see the custom cam sync and crank trigger and other EFI parts. https://www.youtube.com/watch?v=1CdKlTMNGp4
Re: 514 on the dyno
[Re: AndyF]
#2331512
07/04/17 06:49 PM
07/04/17 06:49 PM
Posts: 14,478 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
When I try and open the attachment all I get is " network connection is lost"
Re: 514 on the dyno
[Re: AndyF]
#2571591
10/30/18 01:41 PM
10/30/18 01:41 PM
ZIPPY
S.E. Michigan
Had a great run with that one, good luck to the new owner.
Rich H.
Esse Quam Videri
Re: 514 on the dyno
[Re: ZIPPY]
#2571605
10/30/18 02:20 PM
10/30/18 02:20 PM
AndyF
Had a great run with that one, good luck to the new owner. Yeah, 8 years of R&D. I tested a lot of ideas out on that engine. Very nice solid engine. The rear of the block is bone dry, never had any sort of oil leak during on those years of testing. Last compression test I ran showed 240 psi in each cylinder so the block really held up well. Too bad they stopped making them.
Re: 514 on the dyno
[Re: AndyF]
#2571681
10/30/18 05:02 PM
10/30/18 05:02 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Thats a killer engine, I know the new owner must be thrilled. Looking forward to seeing whats next for you..
2 kids and a dog
