1970-1 A Body Exhaust Manifold Question #2553083
09/21/18 10:53 PM
09/21/18 10:53 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Are there any factory BB exhaust manifolds that would work on a 440 in a 1970-1 A Body ?
Re: 1970-1 A Body Exhaust Manifold Question [Re: 44D6PAKCUDA] #2553137
09/22/18 01:05 AM
09/22/18 01:05 AM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Check out the:
Big Block A body Tech
Swapping a B/RB into your A-Body, Maintenance, Repair & Modifications section on ForABodiesOnly.com
Chuck
When you work on Spaceships for a living, how bad can a workday be?
Re: 1970-1 A Body Exhaust Manifold Question [Re: 44D6PAKCUDA] #2553156
09/22/18 02:18 AM
09/22/18 02:18 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, any of the 67-69 Dart 383 or 440 manifolds will also fit a Duster, you may also need to use the stock 67-69 Dart motor mounts and K-member to properly locate and clear everything but they will probably also work with other mounts like Shumachers.
