392 power steering issue #2553080
09/21/18 10:46 PM
09/21/18 10:46 PM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
I have a 2015 392 in a truck with a crown Vic k member and rack n pinion. New power steering pump from Bouchillon and it keeps popn off the pressure side hose. It's a -6 braided line with an fitting. Any ideas what's going on ?
Re: 392 power steering issue [Re: CRT] #2553086
09/21/18 11:02 PM
09/21/18 11:02 PM
Australia
aus370 Offline
aus370  Offline
Australia
With the pump putting out 1200 - 1600 psi , you will need to use the teflon hose and the appropiate fittings on the pressure side .
look for something with a rating of around 3000 psi , most of the fitting brands sell it and you can still assemble your self.
Re: 392 power steering issue [Re: CRT] #2553088
09/21/18 11:07 PM
09/21/18 11:07 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
is it PTFE hose? Did you install the compression collars into the fitting?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
