Power windows #2553026
09/21/18 08:20 PM
09/21/18 08:20 PM
USA
challenger6pack Offline OP
USA
I was collecting a set for my 69 Satellite. I am unsure if these are correct. Do I have two different years here or is it one set. Thanks.
Re: Power windows [Re: challenger6pack] #2553127
09/22/18 12:27 AM
09/22/18 12:27 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Looks like a set of 4 to me. Don't know what year the system fits, but if your 69 had power windows, there is a pretty good chance that is what it fits. The one with the 4 button switch is the driver's door. My guess is the one to its right is the other front door. The bottom two should be the rear door units, The one on the lower left is laying the wrong direction compared to the others, and may not be all the way up (or down) like the others are. Gene
Re: Power windows [Re: challenger6pack] #2553134
09/22/18 12:59 AM
09/22/18 12:59 AM
USA
USA
Thank you for your help.
Re: Power windows [Re: challenger6pack] #2553378
09/22/18 09:29 PM
09/22/18 09:29 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Are those from a b body or a C body. The base and the gears is the same but the window arms are longer. I install a set from a C body on my 68 GTX, you just swap the arms. I also drilled them to take out a 1 1/2 lbs from each to only add 10 lbs from adding power windows.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Power windows [Re: challenger6pack] #2553379
09/22/18 09:33 PM
09/22/18 09:33 PM
BDW Offline
BDW  Offline
I admire the effort, not sure I would have been that aggressive on that long arm, lots of torque.
