Weird Slap Stick Function
#2552997
09/21/18 06:58 PM
09/21/18 06:58 PM
Posts: 364 US
f2502011
US
I've found that if I start out in first and put the throttle most of the way down the selector will actually move from 1-2 and 2-D on it's own fairly prematurely. I can also bump it and move it to the next gear but I have to be quick as it does it by itself. Any ideas?
Also if the car is in high gear (3rd) and I floor it, it will not kick down, just stays in 3rd. Thoughts/Solutions?
1970 EK2 T/A 727
Re: Weird Slap Stick Function
[Re: buildanother]
#2553096
09/21/18 11:17 PM
09/21/18 11:17 PM
Posts: 364 US
f2502011
US
Something is amiss. The shifter should not change gear position on it's own. Yes I know. Any solutions?
1970 EK2 T/A 727
[Re: f2502011]
#2553155
09/22/18 02:16 AM
09/22/18 02:16 AM
Posts: 4,319 St. Louis, Mo
318 Stroker
St. Louis, Mo
On my slap stik, I could put it in 1st and push it all the way into neutral without stopping in 2nd or drive. I took it out and cleaned it well. Years of dust, hair, dirt, etc had it all clogged up. A good cleaning, and a little lube, and it is good as new.
[Re: 318 Stroker]
#2553181
09/22/18 10:28 AM
09/22/18 10:28 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
they are very simple take your console off and watch it as you move it and make sure the stop is reengaging(sp)usually its just a clean and lube prob.but could be a worn part.
[Re: poorboy]
#2553221
09/22/18 01:15 PM
09/22/18 01:15 PM
Posts: 293 Spanaway, Washington State
patosmith
It sounds like its time to fix the broken motor/trans mounts, or fix the broken slap stick mechanism, I suppose an adjustment might help if the problem was 1-2 and maybe 2-3, but going from 1-2 and then 2-3 is pretty unusual.
Those are the only 3 reasons I ever ran across for a Slap Stick not to function correctly. Gene I agree with this. Check your mounts.
[Re: f2502011]
#2553373
09/22/18 09:10 PM
09/22/18 09:10 PM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
Also if the car is in high gear (3rd) and I floor it, it will not kick down, just stays in 3rd. Thoughts/Solutions? Also sounds like you need to adjust your kickdown linkage for this problem. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
