70 B body muffler hanger attach bolts #2552906
09/21/18 03:46 PM
09/21/18 03:46 PM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
Looking for details or photos of the bolt/screw that attaches the tail pipe hangers to the two brackets behind rear seat on 70 B body. The picture below is the bracket for the LH side....RH is welded to floor. I am seeking info on the fastener that installs into the black clip. Thanks in advance! Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 B body muffler hanger attach bolts [Re: 70gtx440dana] #2553002
09/21/18 07:14 PM
09/21/18 07:14 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
it is a 5/16" x 3/4 long "H" bolt. the washer is conical and is dis-attached. not fixed, or captured.
HEMI,S ARE FOREVER!!!
Re: 70 B body muffler hanger attach bolts [Re: 70gtx440dana] #2553067
09/21/18 10:03 PM
09/21/18 10:03 PM
Lansing, MI
Lansing, MI
Thanks! I will look through my stash to see what I have. Maybe someone else will chime in with photos!
Re: 70 B body muffler hanger attach bolts [Re: 70gtx440dana] #2553085
09/21/18 10:57 PM
09/21/18 10:57 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
According to Moparr Motors fastener restoration reference manual, the 1970 bolts were 5/16-18 x0.625 long and had captive washers 0.63" diameter and were SEMS bolts - "H" bolts were used in 1968/9.
If you are looking for the correct nuts for the LH bracket, they are 1/4-20 Hex Coni Keps nuts with captive washer. The washer is 0.63" diameter.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: 70 B body muffler hanger attach bolts [Re: 1969 HEMI R-T] #2553147
09/22/18 01:56 AM
09/22/18 01:56 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
This is correct for left side 1970, right uses captive washer sems bolt. 4 nuts to hold bracket are captive washer style like the bolt manual says.
