Re: 8 1/4 axle rebuild questions
[Re: dartgame]
#2552497
09/20/18 08:50 PM
09/20/18 08:50 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
yes start with the shim that's on the pinion now, assemble it and see how the pattern looks adjust from there. If you,ve done an 8 3/4 you can do an 8 1/4
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: dartgame]
#2552525
09/20/18 09:31 PM
09/20/18 09:31 PM
Posts: 20,167 Park Forest, IL
slantzilla
Park Forest, IL
I take a small sanding roll on a die grinder and sand out the bore on the new bearing to make it a ton easier to change shims if necessary. Also, if you get the long carrier spanner tool that goes through the axle tube life gets easier too.
