Re: 70 Cuda bolts
[Re: magiccuda]
#2552443
09/20/18 06:58 PM
09/20/18 06:58 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I think they are 1/4in x 3/4in. but dont hold me to it Are they both 3/4" inch long?
Re: 70 Cuda bolts
[Re: Morty426]
#2552472
09/20/18 07:50 PM
09/20/18 07:50 PM
Sammy
Wind Gap,Pa.
Sammy,
There are a lot of different hardware that holds on the valence so you need to be a little more specific.
Also it's different for if your car was made in LA or Hamtramck
Are you taking about the screws that go into the valence brackets?
Let me know and I'll get you an answer.
They are not the same as the exhaust shields
Thanks, if you look from the rear of the car, it's the 2 bolts that are the lowest right under the cutouts for the exhaust tips.
Re: 70 Cuda bolts
[Re: Morty426]
#2552565
09/20/18 10:46 PM
09/20/18 10:46 PM
Sammy
Wind Gap,Pa.
Sammy
Sounds like you are talking about the screws that hold the valence to the rear brackets.
Here is where things get ugly. Here is a picture of 70 cuda mounting brackets with the original screws firmly stuck in them. The have an overall length of 0.75" - top of screw head to the end of the screw. The washer is captured but lose.
Below you will see the reference listing that Dave Wise has for the top and bottom. He shows a screw with the washer being a formed part of the screw head. He lists 10-24 with a thread length of 0.625
Now it could be a difference between the two factories, but all my Challengers have had the lose washer type screw.
Hope this helps.
I have those screws on the top valance as described in the picture in the book. I need the lowest valance bolts with captive washer attached.
Re: 70 Cuda bolts
[Re: gtx6970]
#2552568
09/20/18 10:49 PM
09/20/18 10:49 PM
Sammy
Wind Gap,Pa.
The heat shield bolts are NOT the same as the valance bolts/ studs/ nuts
They ARE the same as the rear axle bumpers and steering linkage shield screws though What size are those bolts ? the ones that I have look to be 1/4-20
Re: 70 Cuda bolts
[Re: Sammy]
#2552635
09/21/18 12:07 AM
09/21/18 12:07 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Sammy
Hope this helps.
I have those screws on the top valance as described in the picture in the book. I need the lowest valance bolts with captive washer attached. A captive washer is a lose washer. The top screws and bottom screws should be the same. Are you saying you need two more screws like what you have in the top?
Re: 70 Cuda bolts
[Re: Sammy]
#2552643
09/21/18 12:26 AM
09/21/18 12:26 AM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
They ARE the same as the rear axle bumpers and steering linkage shield screws though What size are those bolts ? the ones that I have look to be 1/4-20 All of them are 1/4-20. Heat shield screws are an integral washer head machine screws in clear zinc Valance hardware is 1/4-20 sems screws and studs with a free spinning captive washers in black phosphate
