B.B. plastic oil pan gasket with built in windage tray ? #2551984
09/19/18 04:41 PM
09/19/18 04:41 PM
this world
drifter Offline OP
drifter  Offline OP
this world
I have never used this type of oil pan gasket are they any good for sealing? Should I put a thin coat of silicone down on both surfaces or use it dry?
Re: B.B. plastic oil pan gasket with built in windage tray ? [Re: drifter] #2551988
09/19/18 04:57 PM
09/19/18 04:57 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Dry. They work great.
69 GTX 68 Road Runner
Re: B.B. plastic oil pan gasket with built in windage tray ? [Re: drifter] #2551989
09/19/18 04:59 PM
09/19/18 04:59 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
In my experience, they are best used on pans that have a flat sealing surface, unlike the stock sheet metal pans with stiffening dimples.
The sealing ridges in the tray's perimeter don't line up well with the dimples.
Just my 2 cents,
Joe
Re: B.B. plastic oil pan gasket with built in windage tray ? [Re: JERICOGTX] #2551999
09/19/18 05:29 PM
09/19/18 05:29 PM
this world
drifter Offline OP
drifter  Offline OP
this world
On a stock pan it worked great for you?
Re: B.B. plastic oil pan gasket with built in windage tray ? [Re: drifter] #2552109
09/19/18 10:51 PM
09/19/18 10:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I use it with a stock pan. It works good with some Hylamar on the pan side. I usually use Hylamar on most of my gaskets that I may have to remove at some point.
Master, again and still
