starting line controller setups #2551492
09/18/18 01:51 PM
09/18/18 01:51 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
I still have my factory throttle cable, so not sure if that will work or if I will need to change it. Would like to see pics how you guys have yours setup for idea. Thanks.
Re: starting line controller setups [Re: DusterKid] #2551733
09/18/18 11:50 PM
09/18/18 11:50 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I'm pretty sure you'll want a solid linkage...I use this style that will work as a SLE or throttle stop, and you don't get the funky pedal when trying to back up like the inline starting line controllers.
Re: starting line controller setups [Re: DusterKid] #2551875
09/19/18 11:33 AM
09/19/18 11:33 AM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
The oem cable was too erratic. The device tended to droop. Morse or solid rod. twocents
Re: starting line controller setups [Re: DusterKid] #2552342
09/20/18 02:48 PM
09/20/18 02:48 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Solid rod and an air inline stop on the Arrow. I leave at my stop RPM of 3800 and stay on for .020......kills the wheelies for me smile
5.53 @ 125 1/8th on the launch control..more left in her!
