Re: Hopping up my 318
[Re: Brandon_689]
#2551638
09/18/18 07:40 PM
09/18/18 07:40 PM
Posts: 17 Canada
Brandon_689
Canada
Would it be worth running kb167 and say an edelbrock head with out zero decking it due to I've already sent it machine shop would prefer not to have to take it back. And I know i would just prefer to stick with what is supposed to be in my car
[Re: Brandon_689]
#2551653
09/18/18 08:27 PM
09/18/18 08:27 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
All that said, 360 cores are a dime a dozen. I think you’re onto something there.
[Re: roadrunninMark]
#2551762
09/19/18 12:37 AM
09/19/18 12:37 AM
Porter67
China man must say no selly to greedy American. quote=roadrunninMark]I am doing my 318. I went with the kb167 pistons. I didn't want to deck mine for the same reason as you. I am looking at the Sidewinder heads (63cc) and the soon to be released Trick Flows (60cc). I would like the Sidewinders as the price will be better and I really don't need the TFs. The problem is the vendor can't get them from the supplier, so I may have to go with the TFs. The TFs are gonna be great heads but are more than I want to spend. I think the eBrocks are 65cc? [/quote]
[Re: Porter67]
#2552315
09/20/18 01:58 PM
09/20/18 01:58 PM
RapidRobert
Can we talk you into finding a 360 block & stroking it (4" cranks are cheap nowadays) & the KB 356 (iirc) pistons ain't too bad. NOBODY that I have even spoken with that has stroked one has regretted the reasonable time/expense it takes to do one. You get alot of cubes (408) in a SB package. You have a bit invested in the 318 but I dont think you will get what you are seeking from it & once the 408 fries the tires one time you will forget all about that 318!
[Re: Jerry]
#2552410
09/20/18 05:33 PM
09/20/18 05:33 PM
RapidRobert
^^^ Ding ding ding I (do) believe we have a winna! That would kick some tail. I'd want one all under the hood, no cutting.
[Re: Brandon_689]
#2552467
09/20/18 07:40 PM
09/20/18 07:40 PM
Posts: 20,733 A collage of whims
topside
A collage of whims
Another alternative would be to just clean, re-gasket, paint & detail the engine as a display. Sure, it's not a Hemi, but it's sentimental, and would still be pretty cool as a display. I'm assuming it's just your Dad's engine you have, not the whole car. If I were to find my Dad's old Sport Fury, I'd want it how I remember it (stock), except maybe a more modern brake system.
[Re: 65rbdodge]
#2553293
09/22/18 05:21 PM
09/22/18 05:21 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I often wonder if on the brand x boards if the same thing happens when a 305 is mentioned. Just build a 350!!!! Or I’m building a 302. Just build a 351!!! Actually, the 305 is a generally reviled POS even by the Chevy guys and yeah, they'll tell you to build something else. As for the 302, that one depends. In a lot of applications wedging in a 351 is nigh on impossible, so the 302 get the nod because it has a shorter deck and fits better, but they'll stroke it to 347 or bigger in a heart beat. But if there's room, a 351 get's the nod. It costs virtually the same to build either the 318 or the 360 and it's foolish to go with the 318 unless you have an otherwise compelling reason.
[Re: RapidRobert]
#2553305
09/22/18 06:12 PM
09/22/18 06:12 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Can we talk you into finding a 360 block & stroking it (4" cranks are cheap nowadays) & the KB 356 (iirc) pistons ain't too bad. NOBODY that I have even spoken with that has stroked one has regretted the reasonable time/expense it takes to do one. You get alot of cubes (408) in a SB package. You have a bit invested in the 318 but I dont think you will get what you are seeking from it & once the 408 fries the tires one time you will forget all about that 318! 408,408,408. Man do I get tired of hearing this. Do you know how many 408 my kid runs faster than every week with a stock crank 360. LMAO. Oh and its 3200 pound too. Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr
