Re: 383 engine rebuilding in California? Any recommendations?
[Re: Luis Zavala]
#2551565
09/18/18 04:25 PM
09/18/18 04:25 PM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
If anyone says they can rebuild your 383 at standard bore before it is disassembled and the bores measured then they are lying and you should walk away. Actually run away would be more appropriate.
[Re: Luis Zavala]
#2551632
09/18/18 07:21 PM
09/18/18 07:21 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
If you do have to bore it, PLEASE do your research on replacement pistons, get in touch with a piston manufacturer like Diamond ECT, a off the shelf rebuilders will put you in the high 7,low 8 to one compression,PLEASE listin.
[Re: Luis Zavala]
#2551656
09/18/18 08:29 PM
09/18/18 08:29 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m sure the guys at IMM could fix you up.
