Re: 70 Charger Bumper to Hood Rubber Filler Strip Fasteners?
[Re: 71TA]
#2551589
09/18/18 05:26 PM
09/18/18 05:26 PM
Posts: 3,518 Lansing, MI
70gtx440dana
Lansing, MI
James - They are the same phillips head screw with loose washer as used for the washer bottle and fuel tank to trunk floor rubber seal on Charger. I just purchased a new repop set a few weeks back off Ebay. I have originals too if you would like photos. These sames screws attach the rubber strips at front of fender on 70 Charger too. Ebay link
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 71TA]
#2551707
09/18/18 10:49 PM
09/18/18 10:49 PM
Posts: 12,422 Warren, MI
71TA
Warren, MI
[Re: 70gtx440dana]
#2551757
09/19/18 12:32 AM
09/19/18 12:32 AM
Posts: 18,153 Mass
DAYCLONA
Mass
James - These sames screws attach the rubber strips at front of fender on 70 Charger too.
1969 Daytona hood/nose cone and fender seals as well...
[Re: 71TA]
#2551780
09/19/18 01:32 AM
09/19/18 01:32 AM
70gtx440dana
Lansing, MI
They look correct to me.....
[Re: 71TA]
#2552294
09/20/18 01:17 PM
09/20/18 01:17 PM
70gtx440dana
Lansing, MI
I can't speak for 69 Daytona. However, I am 99% confident that 70 Charger has the same screw for the hood rubber and fender rubbers. I parted several of these cars over the years and have a large bag of the original screws. They are all the same style with loose washer.
If someone can provide proof of the 2 styles of screws I would appreciate it too. I am ready to install the fender rubbers on my car and would like know I am using the correct screw style.
[Re: 71TA]
#2552519
09/20/18 09:23 PM
09/20/18 09:23 PM
71TA
Warren, MI
Also...
"#3. The first two fasteners in this photo are Phillips head screws, used to attach the rubber seals to the fender and valance. The black phosphate finish is correct. The last fastener shown is the Phillips head screw, used to attach the nose-to-hood seal to the top rear of the nosecone."
So the "washer bottle" screws are correct for the DAYTONA nose to hood seal installation. 70 Charger may be machine screws though.
[Re: 71TA]
#2552532
09/20/18 09:48 PM
09/20/18 09:48 PM
70gtx440dana
Lansing, MI
Also...
Certainly looks like 69 Daytona and 70 Charger have some differences in the attach hardware. I would like to see more info on 70 Charger fender seal rubber attach screws. Hopefully, someone can post some photos of a survivor.
[Re: 71TA]
#2555713
09/27/18 09:52 PM
09/27/18 09:52 PM
71TA
Warren, MI
Thanks to John, charge70, who loaned me the 3 screws I was asking about so I could document them. I'll share the info.
In the picture below.
Top screw is the Mopar washer bottle screw, fuel filler tube to trunk floor seal screw and 69 Daytona hood to nose filler strip attaching screw. Commonly available.
Middle screw is the 70 Charger hood to nose filler strip attaching screw. This is a machine screw presumably because it's threading into a tapped steel angle bracket instead of sheet metal like on the 69 Daytona (the 70 Charger and 69 Daytona, which has a 70 Charger hood, use the same rubber gap filler between the hood and the frt bumper or nose hence my questions about the fasteners). Found a screw with the exact same head, thread and plating but about 1/8" shorter and doesn't have the self tapping feature. Once installed you couldn't tell.
Bottom screw is the attaching screw to attach the rubber fillers between the front of the fenders and the bumper or nose TO the front edge of the fender on a 70 Charger or 69 Daytona. Found a screw with exact same head, thread and plating but is 1/4" longer. Not sure but doubt that'd be an issue. And again length wouldn't be noticed once installed.
All these rubber pieces also use stamped brackets along with these screws to hold the rubber pieces in place but anyone even remotely interested in this probably already knows this.
[Re: 71TA]
#2555915
09/28/18 11:46 AM
09/28/18 11:46 AM
70gtx440dana
Lansing, MI
Nice work James! Thanks for your continued support of our hobby! Joe
[Re: 71TA]
#2556017
09/28/18 03:45 PM
09/28/18 03:45 PM
70gtx440dana
Lansing, MI
70 Charger 426 Hemi survivor photo below. As usual with Ma Mopar there may have been more than one variety of screw used during the model year.
